1999 Cruise control problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WNC newbie, this thread has received 2 replies and been viewed 992 times.
post #1 of 3 (permalink) Old 01-23-2009, 01:51 AM Thread Starter
I didn't want to hijack the other cruise control thread, so here is my issue. When I set my cruise, it will sometimes just keep accelerating. Other times it will set on the correct speed for miles and then suddenly start accelerating on its own. Anyone else have this issue, or have any idea how to fix it?
WNC newbie is offline
post #2 of 3 (permalink) Old 01-23-2009, 01:47 PM
2nd Gen Guru
Mopar1973Man's Avatar
Well...
I'll give you a bit of insight... I'm pretty sure you got a vacuum motor on your truck that controls the throttle. There is 3 valves that control the vacuum into the vacuum motor for throttle control. Maybe a valve is sticking???
Then there has been issues with the clock spring in the column before but typically it break and there is no control.
At least its something to chase...
Mopar1973Man is offline
post #3 of 3 (permalink) Old 01-24-2009, 02:12 AM Thread Starter
Thanks for the reply. I don't know much about them, it just seems odd that I can be on cruise at 65 mph for miles and it will suddenly just begin accelerating, and keep accelerating until I tap the brakes.
Thanks again.
cruise control/ABS problem tjigger 2003-2007 6.0L Power Stroke 5 04-09-2008 10:18 PM
Another cruise control problem mpropst 2003-2007 6.0L Power Stroke 8 04-07-2008 08:27 PM
Cruise Control CBF 2003-2007 6.0L Power Stroke 7 03-18-2008 04:43 PM
cruise control problem DieselDadio 1994-2003 7.3L Power Stroke 17 05-27-2006 05:04 AM
Cruise control problem diesel_demon 1994-2003 7.3L Power Stroke 8 03-30-2006 03:22 PM
