Dash Removal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Taylor34, this thread has received 4 replies and been viewed 997 times.
post #1 of 5 (permalink) Old 01-23-2009, 02:53 AM Thread Starter
Taylor34's Avatar
Dash Removal
How hard is it to remove the dash...i got more cracks in my dash than what an addict would have...im thinkin about goin to the junkyard and pullin one out of a truck there or is it easier to just buy one of those dash covers that fit right over the top
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #2 of 5 (permalink) Old 01-23-2009, 06:03 AM
just cover it as the one you pull will crack too
01quadcab is offline
post #3 of 5 (permalink) Old 01-24-2009, 01:45 PM
2nd Gen Guru
Mopar1973Man's Avatar
I've heard there is a cap replacement you can put on top that bind it all back together and covers the broken areas...
Mopar1973Man is offline
post #4 of 5 (permalink) Old 01-24-2009, 04:51 PM Thread Starter
Taylor34's Avatar
alright i found that i can get a junkyard one for 25 bucks if i pull it out and then i seen the ones on the internet for 160 so i was debating if it would be hard to pull out the junkyard one of just buy the cap
Taylor34 is offline
post #5 of 5 (permalink) Old 01-29-2009, 12:36 AM
I put one from the junk yard on my son's 95 and it's been holding up fine for the last 11 months. I just got one for my 01, $50 at junk yard. Somebody started to take it out and quit. I only had to remove 4-5 screws on the back side of the dash. I will put it in when the weather warms. The 01's are easier I think because the screws are easier to get to. I'm attaching a thread I found someplace, this should help. Use a mirror to help locate the screws on the back side of the dash by the windshield or look thru the windshield. I think there are 4-6 screws you need to remove. The defroster duct work can stay on the dash top cover. You do not need to completely remove the dash. Only loosen the bolts at the bootom of the dash and pivot away from the windshield like in the photos.
2001.5 Ram 2500 Quad Cab, HO, 6 speed, 4.10's, RV275 injectors, Quadzilla XZT+, AFE 4" Exhaust, ISSPRO Gauges (EGT, FP, Boost), K&N Air Filter, Raptor 100 Fuel Pump, 1/2" line with AN fittings to the factory fuel filter, 6AN fittings from fuel filter to injection pump.
dave2001 is offline
The Following 2 Users Say Thank You to dave2001 For this addition to TDG:
later (02-01-2009), Taylor34 (01-29-2009)
Analog dash to Digital dash? skav 1994-2003 7.3L Power Stroke 4 03-28-2008 03:50 PM
Dash Board Removal Rageous 1994-2003 7.3L Power Stroke 11 01-29-2008 12:08 AM
Dash Cluster Lens Removal circle5 1994-2003 7.3L Power Stroke 2 01-25-2007 12:03 AM
Dash removal? adrianspeeder General Ford Truck and Excursion 3 07-14-2006 02:25 PM
EX dash trim vs. F250 dash trim? sredish 2003-2007 6.0L Power Stroke 13 06-15-2006 02:29 AM
