New Tranny! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeffybuilt, this thread has received 9 replies and been viewed 842 times.
post #1 of 10 (permalink) Old 01-24-2009, 03:21 AM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
New Tranny!
I got the truck back today and it's awesome! Just really happy to be out of that honda civic! One question though...I hooked up my tranny temp gauge, and when test driving the truck, the gauge wouldnt go above the 100 degree mark, which is what it starts on...I didnt drive it for that long, maybe 20 minutes or so. Is it possible that with it being cold outside, new fluid and a clean and flushed system the fluid isnt even getting over 100 degrees? I will be back on the highway with it sunday, so we'll see than, but I was wondering if anyone has some common temps they can tell me. Thanks.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #2 of 10 (permalink) Old 01-24-2009, 09:15 AM
Ghost
Phily's Avatar
Yes it's possible. Check your fluid make sure it's ok and temp sending unit, etc. Alot of people on here with good rebuilds swear their temps can't even get close to 200.
Phily is offline
post #3 of 10 (permalink) Old 01-24-2009, 05:02 PM
it depends on where your probe is. mine is in my hotline so I can see temps coming right out of the converter. The probe in the pan can be deceiving as your getting temps after the fluid has gone through the coolers. If thats where your probe is then it will take a while to build up heat to there. Even with my probe I see driving temps of 130-145 only time it gets above that is when the converter is not locked
01quadcab is offline
post #4 of 10 (permalink) Old 01-24-2009, 06:29 PM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Ok, thanks. My probe is in the rear pressure test port. I read that the test port temps are usually around 20-30 degrees hotter than in pan readings, and generally in pan readings are 60-80 degrees above ambient temperature, so if its 15 degrees here now, than under light driving and short distance, my temp should be around 95-100 degrees or so....Like I said, I will have it out on the highway for a few hundred miles again tomorrow, so I'll see what it does.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #5 of 10 (permalink) Old 01-24-2009, 11:09 PM
Ghost
Phily's Avatar
You have in a test port? Not sure about that one.
You want it in the pan, the fluid in the pan is the stuff that is about to be sent to the transmission. Who told you put it in a test port?
Phily is offline
post #6 of 10 (permalink) Old 01-25-2009, 12:03 AM
Thats always been my line of thinking too. I know coming right out of the converter gives you the highest temp, but in the pan like you said, is what is getting sucked up into the trans.
Driving around on the highway, with mine in the pan, on a cool night, i.e. 45* or so I'm only at around 125* on my gauge, even on a 6hr trip.
post #7 of 10 (permalink) Old 01-25-2009, 05:24 AM
thats where edge has you put it in their install manual for the juice.
post #8 of 10 (permalink) Old 01-25-2009, 02:09 PM
Ghost
Phily's Avatar
Interesting............
I guess they probably just do that because it's easier than figuring something out with your pan or case.
Phily is offline
post #9 of 10 (permalink) Old 01-25-2009, 07:07 PM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
I was going to put it in the pan, but the place that did my tranny said they would rather put it in the test port than drill the stock pan...I would have sprung for a deep pan with port, but after $3000 of unexpected tranny bills, I was kind of limited...I think when I have the $$ I will get a deep pan, put the probe in there, and seal off the test port again...anyway, that will be a few months down the road, so I'll see how this works out for now. Thanks guys.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #10 of 10 (permalink) Old 01-25-2009, 07:12 PM
Ghost
Phily's Avatar
I wouldn't worry too much about your temp it's just interesting where the temp gauge is at. It should be fairly accurate.
I've seen people try and make their own drain plug and/or temp probe in stock pans it doesn't work to well. So you did the right thing.
In the future if you want make a interesting,informative thread. Get one of those pans with a place for the temp sending unit. And tell us what the difference in readings are. I'm curious to know what the difference would be, if any.
Phily is offline
The Following User Says Thank You to Phily For this addition to TDG:
Jeffybuilt (01-25-2009)
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
tranny getting hot dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 3 05-12-2007 04:39 AM
What tranny to get TimMiller 1994-2003 7.3L Power Stroke 7 04-29-2006 02:24 AM
Tranny? Smokin Joe 2003-2007 6.0L Power Stroke 16 04-28-2006 03:01 PM
Which tranny PSmokinD 1994-2003 7.3L Power Stroke 35 02-18-2006 02:51 AM
