Two Stroke Oil Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Taylor34, this thread has received 11 replies and been viewed 1180 times.
post #1 of 12 (permalink) Old 01-27-2009, 03:10 AM Thread Starter
Taylor34's Avatar
i just started running two stroke oil this friday and already i can tell that my truck is just a little bit quieter but i have a question do i always need to use universal two stroke oil or can i buy the outboard two stroke oil bc our walmart only has the outboard in big bottles
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #2 of 12 (permalink) Old 01-27-2009, 04:50 AM
TDG Mafia
Jeffybuilt's Avatar
I have found it easiest to buy the gallon of Wal Mart stuff. I keep it in my tool box, along with a 20oz water bottle. When I fill up, I pour the 2-stroke oil into the water bottle, than into my tank, so there is no mess down the side of my truck.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 12 (permalink) Old 01-27-2009, 05:06 AM
From what ive read as long as its the ASHLESS kind you should be ok. Also do a search on 2 stroke oil theres tons of info on this site about it.
2003 Ford F350 DRW CC LB, H11 studs, 190cc injectors from II,Stage 1 VGT from II, EGR delete, Spearco, Reg Return from dfuser, Magnaflow turboback 4 inch stainless, SCT XCAL3 Tuned by ID, FASS 150/180, 6inch lift, 100 gallon transfer tank, and a bunch of other nic nacs and do dads! DUALLY CLUB MEMBER #74
tattoo6.0 is offline
post #4 of 12 (permalink) Old 01-27-2009, 05:20 AM
ashless is the outboard stuff. it's for low rpm 2strokes not like the dirt bikes and chainsaws that love to rev. Just look at moparmans site and follow his directions. I do the same thing as you do jeffybuilt, but I have a case of bottles I fill up and take them with when I go on road trips. Less mess on the road just save the bottle.
01quadcab is offline
post #5 of 12 (permalink) Old 01-27-2009, 01:06 PM
2nd Gen Guru
Mopar1973Man's Avatar
I've used just about any kind of 2 cycle oil out there...
Full Synthetics, Semi-Synthetics, Petroluem based...
PennzOil, Valvoline, SuperTech, YamaLube, Phillips 66 Injex, etc...
Snowmobile, Chainsaw, Outboard motor, etc...
Basically what every you can find that is cheap and fits you pocket book as long as its ASHLESS it will work...
Mopar1973Man is offline
post #6 of 12 (permalink) Old 01-27-2009, 06:20 PM Thread Starter
Taylor34's Avatar
alright i just seen that there was universal and outboard there and i figured id just run the universal cuz it was cheaper but it doesnt come in anything bigger than 8oz but i havent gone to tractor supply yet
Taylor34 is offline
post #7 of 12 (permalink) Old 01-27-2009, 08:01 PM
JLWelding's Avatar
I told a friend about two stroke and he said he had a case in his shop that came from he father who had past away. And asked will this work and label said Sinclair. I think I spelled that right. His father owned the old station back in the late 60s. Do you think its ashless?
JLWelding is offline
post #8 of 12 (permalink) Old 01-28-2009, 03:58 AM
So as long as it is TC3W it ok. Right?
2001 Dodge quadcab 4x4,Auto transmission,Fass 150/150 pump, Among other upgrades.
todt061458 is offline
post #9 of 12 (permalink) Old 01-28-2009, 11:05 AM
could you just use new motor or used motor
cummins-dodge is offline
post #10 of 12 (permalink) Old 01-28-2009, 12:38 PM
JLWelding's Avatar
Low to no flash point is my thought. And no lubrisity just MHO I am no expert,I am sure he will be along in a minuite.
2 Stroke Oil Question BocaCobra03 2008-2010 6.4L Power Stroke 39 04-05-2009 01:53 PM
2 Stroke Oil Question BocaCobra03 2003-2007 6.0L Power Stroke 32 01-28-2009 03:00 AM
2 stroke oil BriteWhiteRam 5.9L Cummins (2003-2007.5) 46 02-16-2008 10:46 PM
New Stroke In Ok nymikeok Introductions 7 12-15-2006 12:33 AM
2 stroke or 4 stroke!? Deezle1 4X4 Offroad Forum 25 11-27-2005 02:31 AM
