fuel pressure during idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SparkyLV, this thread has received 35 replies and been viewed 4042 times.
post #1 of 36 (permalink) Old 01-28-2009, 12:05 AM Thread Starter
Indecisive
Send a message via AIM to SparkyLV
Just installed edge juice with attitude on the truck.
Fuel pressure while idling is like 11-12 psi?
Is this normal?
Just is a lot lower than my ford was.
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #2 of 36 (permalink) Old 01-28-2009, 01:15 AM
Heavy Equip. Is My Life
Sounds low, idling should be around 15 to 20 psi I believe. Mopar1973Man has an excellent write up on his website; mopar1973man.com.
Russ
Late '99 F-350 7.3l 6sp 2wd Aftermarket dually kit 186,000mi STOCK
'99 Dodge 3500 24v 47re QCLB 4x4 DRW 131,000mi Straight-piped
'97 Chev 3500 6.5TD Auto-OD ECLB 4x4 DRW 199,000mi 4" exh. turbo to bumper
Deeslfxr is offline
post #3 of 36 (permalink) Old 01-28-2009, 01:43 AM
before i put my airdog on mine was 13psi
dodgetheonlytrk is offline
post #4 of 36 (permalink) Old 01-28-2009, 01:59 AM
Taylor34's Avatar
i have the stock lift pump and mine bounces anywhere from 12 to 16 during idle
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #5 of 36 (permalink) Old 01-28-2009, 02:10 AM
TDG Mafia
Jeffybuilt's Avatar
That is correct...fuel pressure at idle should be around 15-16psi. No more than 20psi, and should never drop below 10psi. If your fuel pressure is 11-12 at idle, its probly dropping into the single digits while driving-acceleration = more fuel demand = dropping fuel pressure.
When was the last time you changed your fuel filter? Its possible your filter is REALLY clogged, but most likely your LP is weak...Lucky for you, you may have caught it in time as not to have ruined your VP44 yet....
Anyway, start by changing the fuel filter, and if that dosent help, you need to replace the LP...should get a better one anyway. Most guys on here have either the Air Dog or FASS system, or like me, I have a Holley pump and system I put togeather for about $150 bucks...works great.
Hope that all helps!
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #6 of 36 (permalink) Old 01-28-2009, 03:07 AM
Taylor34's Avatar
why cant we go over 20psi when the 12v guys are pushing 50 or more
Taylor34 is offline
post #7 of 36 (permalink) Old 01-28-2009, 03:26 AM
because they ppump is a different beast. Our pump doesn't like heat or high pressure the diaphragm is what doesn't like it.
01quadcab is offline
post #8 of 36 (permalink) Old 01-28-2009, 03:28 AM
Taylor34's Avatar
ah gay...what was dodge thinking when they designed this
Taylor34 is offline
post #9 of 36 (permalink) Old 01-28-2009, 04:25 AM
Not to be a pooper but you should Bosch, because they made the injection pump.
silvrcummns is offline
post #10 of 36 (permalink) Old 01-28-2009, 05:06 AM Thread Starter
Indecisive
Well I did fuel filter 3 weeks ago, So im thinking its LP then!
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Is this normal oil pressure at idle? dropped_dually Duramax 2004.5-2005(LLY) 6 12-19-2007 06:42 PM
how much oil pressure at idle when warm? SICKS-O 1994-2003 7.3L Power Stroke 3 06-14-2007 04:15 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Low Idle and Oil pressure gauge drops engine hot only BIG BLUE 5.9L Cummins 12 Valve (1994-1998.5) 3 03-05-2007 02:43 PM
