edge injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skyjacked84, this thread has received 31 replies and been viewed 2497 times.
post #1 of 32 (permalink) Old 01-29-2009, 12:35 AM Thread Starter
edge injectors
good or bad? im thinkin about gettin the stage 5 for my 2002
skyjacked84 is offline
post #2 of 32 (permalink) Old 01-29-2009, 04:15 AM
TDG Mafia
Jeffybuilt's Avatar
Im sure some guys on here actually have them and will chime in, but this is what I have heard about those...
First of all, I have heard they run REALLY hot. So if you are towing they are a bit sketchy. Also, what other mods do you have so far to your truck? Passing extra fuel, you will need to supply more fuel to keep your IP happy...and gauges...etc.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 32 (permalink) Old 01-29-2009, 05:10 AM
Official TDG Doctor
hccumminssmoke's Avatar
They don't run hotter then any other i have ever been around...Get full dont go with the nozzels, and new full injector will be better in the long run imo...
Nate
hccumminssmoke is offline
post #4 of 32 (permalink) Old 01-29-2009, 05:38 AM Thread Starter
nothing, yet. im gettin ready 2 build it up. its my second truck an only gets used maybe 4 weeks a year. so far from what ive been told, gauges first all four. then an Adrenaline Engine Control System, stage 5 injectors, fass VP44 cover. intake 4" turbo back exhaust. so im gettin all the parts together so next time im home ill be blowin smoke.
post #5 of 32 (permalink) Old 01-29-2009, 06:16 AM
if you get the quad box get the pulse and your gauges are taken care of in the pulse all but the fuel pressure gauge that is. If your going the big on injectors you need a turbo if not turbos. With a new turbo it will have an hx 40 downpipe and usually cheaper to go to a exhaust shop and have the finish it out for you... or not I don't know.
01quadcab is offline
post #6 of 32 (permalink) Old 01-29-2009, 02:35 PM
haz-mat19's Avatar
Yep, you are going to need to address your turbo if you want to dive it with out melting it , plus your trans is not going to hold if it is stock. If you have an auto you will need a new converter and V/B minimum and a new clutch if you shift your own.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #7 of 32 (permalink) Old 02-11-2009, 09:07 AM
Look at some Fireball Pro 150 or 200 Injectors
DieselDawg is offline
post #8 of 32 (permalink) Old 02-12-2009, 05:30 AM
I would get a different brand of injectors than the edge. a set of ddp or similar high quality injectors
post #9 of 32 (permalink) Old 02-12-2009, 04:07 PM
Official TDG Doctor
I would not go with edge, not b/c they are not good, but you can find the same thing, if not better...DDP makes good sticks and the Scheid Lightnings are great imo...
Nate
post #10 of 32 (permalink) Old 02-12-2009, 05:49 PM
Indecisive
Send a message via AIM to SparkyLV
So why are you telling him to go with other injectors other than the edge ones?
I thought they where some nice sticks?
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
edge jammer injectors O2CUMMINS 24 Valve Performance 9 03-13-2008 03:38 AM
blown injectors with edge lil_jeff_a 5.9L Cummins (2003-2007.5) 7 12-14-2007 11:21 PM
98-02 Edge Jammer stage 4 injectors Cummins5390 Whats Been Sold 1 12-04-2007 12:57 AM
Injectors vs. Edge comp STROKER SMOKER 5.9L Cummins (1998.5-2002) 20 04-21-2007 12:32 AM
Edge Jammer Injectors? diesel_ram_man 5.9L Cummins (2003-2007.5) 1 05-31-2006 11:09 AM
