Exhaust Brake Electornics - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rwhite, this thread has received 6 replies and been viewed 874 times.
post #1 of 7 (permalink) Old 01-29-2009, 05:05 PM Thread Starter
My question is this, on my truck I have a Banks exhaust brake (came w/ the truck) I have the high idle flash and the high idle will only kick on after the exhaust brake (EBPV?) has run for a short time. Will putting a high idle switch on the truck hurt any electronics? Does the Banks Brake have any electronics that are associated w/ it? Sorry for the long post. Thanks.
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #2 of 7 (permalink) Old 01-29-2009, 08:40 PM
Ghost
Phily's Avatar
Long post? I think you need to actually elaborate more.
Phily is offline
post #3 of 7 (permalink) Old 01-30-2009, 02:01 PM
2nd Gen Guru
Mopar1973Man's Avatar
Nope it will be fine...
I'm running the Jacobs exhaust Brake from Dodge. Mine starts and pauses for a short time and then the exhaust brake starts and the high idle. Now be careful the 3 cylinder high idle can produce some seriously high temps! (850*F to 1,000*F worth of pyro!)
Here is my high idle mod I've done...
http://mopar.mopar1973man.com/tips/c.../high-idle.htm
Mopar1973Man is offline
post #4 of 7 (permalink) Old 01-30-2009, 04:06 PM Thread Starter
Mopar Man,
So your exhaust brake will run for a short time and then kick off. In 30 sec. to 2 min your high idle by Dodge TSB standards will kick on. Am I understanding this correctly?
rwhite is offline
post #5 of 7 (permalink) Old 01-30-2009, 08:35 PM
2nd Gen Guru
Actually No...
0 - 60 Secs nothing...
60-120 Secs the exhaust brake starts...
2-3 minutes later... High idle starts with the exhaust brake...
Both continue to run...
post #6 of 7 (permalink) Old 01-30-2009, 10:54 PM Thread Starter
Okay, here is what I have
@ start-up - 10 minutes - depends on temp. hissing sound like brake is active
10 min - brake "kicks off" still have some hissing sound
30 sec-1 min after = high idle starts
I've never had the high idle start any quicker than 5 minutes after start-up
Is it just the truck or the Banks Brake elecronics possibly?
rwhite is offline
post #7 of 7 (permalink) Old 01-31-2009, 01:59 PM
2nd Gen Guru
Totally normal. The ECM software is design to allow for the engine to stablize a bit before adding the high idle to it. Also the hard one I've seen is 3 cylinder high idle starts and the Exhaust brake is on then the grid heaters hit...
That poor Cummins is trying to drag all that load around with 3 cylinders on a cold morning...
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
rwhite (01-31-2009)
Exhaust brake on the 6.0L Best one yet. imported_Six_leaker 2003-2007 6.0L Power Stroke 50 03-28-2008 03:04 PM
Exhaust Brake patriot2500 2003-2007 6.0L Power Stroke 6 08-29-2007 12:51 AM
6.7 Exhaust Brake 07duramax 6.7L Cummins (2007.5-2011) 5 02-24-2007 01:27 AM
Exhaust Brake Farmboy162005 2003-2007 6.0L Power Stroke 1 01-09-2007 06:05 AM
Exhaust Brake ??? Billysgoat 5.9L Cummins (1998.5-2002) 8 04-15-2006 04:44 PM
