smoke switch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins-dodge, this thread has received 7 replies and been viewed 8026 times.
post #1 of 8 (permalink) Old 01-30-2009, 02:50 PM Thread Starter
smoke switch
i have 2001 cummins with edge jucie with additude and i tryed to put a smoke switch in but all it would do is throw codes and cut my power back i tryed both black wires
what am i doing wrong thanks
cummins-dodge is offline
post #2 of 8 (permalink) Old 01-30-2009, 05:36 PM
TDG Mafia
Jeffybuilt's Avatar
Here is a brief video on the smoke switch for a 2001.
Also, just to simplify things, it all has to be one closed circuit with the switch "off" or in the factory/normal mode, and than has to be "cut" when current is diverted....anyway, Im sure you know that.
And yes, It can and usually will throw a check engine light. You shouldnt run with it in gauged, only use it if your playing around and pulling out of somewhere, etc. at low speeds, than shut it off. You may have it installed just fine, but need to turn it off once you start driving.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 8 (permalink) Old 01-30-2009, 05:41 PM Thread Starter
if i turn the switch off it cut my power back to stock even with it on stage 5 and the engine light is still on if i hook a scaner to it and clear the codes then i get my power back
post #4 of 8 (permalink) Old 01-31-2009, 02:46 AM
you have to tap the signal and the 5 volt the 5 volt is one of the black ones get a multi meter and see which one is the right one when you turn it on you will feel the timing advance while driving and your attitude monitor will show alot of boost something is not right on yours from what i read your going into limp mode. you can wire in a resistor and try that think 5 ohm radio shack sells them for about a buck try that also
nick b is offline
post #5 of 8 (permalink) Old 01-31-2009, 12:12 PM Thread Starter
where would i put the resistor on the pink wire or on the black wire
post #6 of 8 (permalink) Old 01-31-2009, 01:49 PM
2nd Gen Guru
Mopar1973Man's Avatar
Here is my setup for my Edge Comp...
http://mopar.mopar1973man.com/tips/c...oke-switch.htm
Mopar1973Man is offline
post #7 of 8 (permalink) Old 01-31-2009, 03:10 PM
it really dont matter just in one of the wires going to the switch
nick b is offline
post #8 of 8 (permalink) Old 01-31-2009, 06:02 PM Thread Starter
will this work with the juice since it has a low boost setting isn't it the same thing or will this add more smoke thanks
map sensor jumper/ smoke switch jroderick 5.9L Cummins (2003-2007.5) 5 05-26-2010 02:55 PM
smoke switch Red Smurf LBZ & LLY Tuner Forum 1 01-12-2009 09:21 PM
Smoke Switch Install STROKINon20s 1994-2003 7.3L Power Stroke 6 04-20-2008 11:44 PM
05 smoke switch Bowz 5.9L Cummins (2003-2007.5) 11 03-19-2008 09:29 PM
