holley blue pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins-dodge, this thread has received 10 replies and been viewed 3162 times.
post #1 of 11 (permalink) Old 01-30-2009, 07:27 PM Thread Starter
holley blue pump
how to get more fuel pressure and how to put 1/2 fuel line in the tank
cummins-dodge is offline
post #2 of 11 (permalink) Old 01-30-2009, 08:22 PM
cowboytw13's Avatar
You're only going to get the the pressure that the pump your using puts out. I don't think you can turn them up. Besides, you can't run high pressure with the VP-44. With an airdog 100, I'm getting 14-15 psi.
As for the draw straw, here is a Vulcan one. I haven't tried it, but it looks promising.
http://www.vulcanperformance.com/Dra...hlo-p/dsiv.htm
This has the draw straw and return all in one unit.
Hope this helps,
Travis
cowboytw13 is offline
post #3 of 11 (permalink) Old 01-30-2009, 08:34 PM Thread Starter
some one said you can strech the spring in them i just want to make sure of that before i do it
post #4 of 11 (permalink) Old 01-30-2009, 11:53 PM
cowboytw13's Avatar
I'm not really sure about that one, what fuel pressure are you running?
post #5 of 11 (permalink) Old 01-31-2009, 07:10 AM
TDG Mafia
Jeffybuilt's Avatar
you can stretch the spring, just be careful when you do it. The spring mine came with was WAY to soft, and would only put out around 7 psi...I was testing with my in cab FP gauge as well as one hooked to the test port, so I knew I was accurate. I ended up using a spring from a click pen, and cutting a few prongs from it and stretching it a bit to get the proper fuel pressure. I currently have 17.5 at idle and about 12.5 at WOT.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
The Following User Says Thank You to Jeffybuilt For this addition to TDG:
cummins-dodge (01-31-2009)
post #6 of 11 (permalink) Old 01-31-2009, 01:46 PM
2nd Gen Guru
Mopar1973Man's Avatar
Holley pumps are a cheap way of getting a pump... But like you see in the above post...
When you you have pressure loss that means that you pump can't supply enough volume of fuel for the demand. So the whole trick is to find a pump that can satisify the demand... Something to think about...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
Jeffybuilt (01-31-2009)
post #7 of 11 (permalink) Old 01-31-2009, 07:24 PM
TDG Mafia
Jeffybuilt's Avatar
When you you have pressure loss that means that you pump can't supply enough volume of fuel for the demand. So the whole trick is to find a pump that can satisify the demand... Something to think about...[/QUOTE]
Yea, I know exactly what you are saying...I guess in my situation, where $ was a factor, I simply wanted something more reliable than stock, but couldnt exactly spend $500 on a pump, ya know. My gauge for normal driving sits at 17.5 idle and runs at a steady 15 no matter what. Its only if I absolutly romp on it from a dead stop will it drop to 12.5 or so. Isn't it normal to see a bit of a pressure drop under heavy acceleration? I was under the impression that 17.5 - a steady 15 was a very healthy system...Thanks for the help!
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #8 of 11 (permalink) Old 01-31-2009, 08:50 PM Thread Starter
i do not have any pressure problems i just would like to up the pressure a little thats have had no problems with the holley pump maybe you have
post #9 of 11 (permalink) Old 02-01-2009, 01:38 AM
2nd Gen Guru
[/quote]
Basically is all about supply and demand... Like you see a 5 PSI drop in fuel pressure and I only see 1 PSI in the same conditions... Just that a AD or FASS can supply more volume constantly than a Holley...
Jeffybuilt (02-01-2009)
post #10 of 11 (permalink) Old 02-01-2009, 02:34 AM
02sprtcumns's Avatar
i ran two pumps on my 02 one being a holley. With the two i didnt have but 2psi drop but also i had about the same money in it as i would have a fass, airdog etc....
02sprtcumns is offline
holley blue Diesel Fanatic 5.9L Cummins (1998.5-2002) 6 09-14-2007 11:02 PM
Holley Blue Install stevenag03 5.9L Cummins (1998.5-2002) 1 08-05-2007 02:45 PM
Holley Blue For Lift Pump xtremexj 2003-2007 6.0L Power Stroke 12 08-03-2007 04:51 PM
holley blue pump redneckchief 5.9L Cummins (1998.5-2002) 27 08-01-2007 05:10 AM
Holley blue pump install Youngone00 5.9L Cummins (1998.5-2002) 4 03-09-2007 09:46 PM
