dead radio and power mirrors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by n-r-zigs, this thread has received 5 replies and been viewed 654 times.
post #1 of 6 (permalink) Old 01-31-2009, 11:44 AM Thread Starter
Send a message via MSN to n-r-zigs
dead radio,power mirrors, i went to adjust my mirror in my 2001 and the radio went dead and no power mirrors now,,checked the fuses all seems well ,am i missing something,,i did not check the fuses in the little holders (iod) i think is one,, should i put more effort into getting those out and look or does someone know were to look otherwise thanks!!!!!!!!
neil :mafia ziegler
n-r-zigs is offline
post #2 of 6 (permalink) Old 01-31-2009, 01:28 PM
99 cummins
customdeluxe78's Avatar
instead of pulling each fuse to check it, use a test light. this saves alot of time and hassle. just turn ignition on (no need to start engine), make sure you put your test light on a good ground and touch each side of the fuse. there is two small holes on every fuse that you can touch the metal on the top without pulling the fuse. if there is not power on both posts, the fuse is bad. this is a good method because sometimes it is hard to see if the fuse is blown just by looking.
hope this helps, good luck
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #3 of 6 (permalink) Old 01-31-2009, 03:08 PM
check the fuse in the cab think its number 15 its the only one with a black cover on it
nick b is offline
post #4 of 6 (permalink) Old 02-02-2009, 05:43 PM
Yep, same thing happened to me, ecept my truck wouldnt start..check those IOD fuses in the holders its on of thoses.
BlackDeath is offline
post #5 of 6 (permalink) Old 02-02-2009, 11:15 PM
Ghost
Phily's Avatar
Well, I don't know where start yet with the mirrors. But the radio. If you don't care for a aftermarket deck (or if you already have one). Just run your own wires. 22awg is what I've found on these and that has a tendency to short out stuff. I'd 16awg for the power and 18awg for the speakers.
Phily is offline
post #6 of 6 (permalink) Old 02-03-2009, 04:19 PM
the same thing happened in my 2000 like 3 days age and it was also my i.o.d fuse its a little tricky getting the clip out but everything works now
steve01 is offline
Power mirrors don't work meh1711 2008-2010 6.4L Power Stroke 2 08-30-2007 03:51 AM
Installing power mirrors on an XL? Fantom3993 General Ford Truck and Excursion 2 07-24-2007 04:58 AM
Power Mirrors AllOut0606 1994-2003 7.3L Power Stroke 6 03-16-2007 08:10 PM
Power Mirrors fuzzys69 General Ford Truck and Excursion 1 03-06-2007 06:00 AM
Power Wire For Radio In 05 Lariet Jakkle5 General Ford Truck and Excursion 1 03-14-2006 02:02 AM
