hot rod pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dallascrwfrd, this thread has received 16 replies and been viewed 1271 times.
post #1 of 17 (permalink) Old 02-01-2009, 05:09 PM Thread Starter
hot rod pump
whats your opinoin on them?how bad do they affect mileage? and what about buying a used one?
dallascrwfrd is offline
post #2 of 17 (permalink) Old 02-01-2009, 11:59 PM
I have a stock VP on my 02, but it is my understanding that a hot rod pump will help performance without major milage reduction it is more up to you and your right foot. I will stay with a stock pump just because I am using a Comp Box to increase performance and milage. A hot rod pump will only give a extra 30 or so hp increase with a Box, and I would just as soon spend the extra money on a box or injectors. Now for the other side of it if you do not have a box and need another pump then it may be what is right for you.
later is offline
post #3 of 17 (permalink) Old 02-02-2009, 10:55 AM
What are sparkplugs
ICEMAN3005's Avatar
I have a stage 2 hot rod P works great tons of power. As for MPG I can't honestly give you an accurate reading, because something in my drive train is binding up feels like I'm standing on the brake even though I'm not. I think its my transfer case because it gets worse in 4 wheel drive. I'm getting between 14-16 MPG right now but when I fix whatever is binding I hope it goes back to 18-20.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #4 of 17 (permalink) Old 02-02-2009, 05:14 PM
Official TDG Doctor
hccumminssmoke's Avatar
Hot Rod Pumps are nice but it is my understanding that they do not respond to electronics well...for instance you might get 120hp out of a SO pump and a Comp, but less with a HRVP 44 and that box...idk if its true but thats just what I have heard...
Nate
hccumminssmoke is offline
post #5 of 17 (permalink) Old 02-03-2009, 02:23 AM
2nd Gen Guru
Mopar1973Man's Avatar
If you planing on replacing a VP44 and this is your daily driver... I would suggest you just head for the Stock SO pump. They do quite well for mild power and except electronics quite well...
Mopar1973Man is offline
post #6 of 17 (permalink) Old 02-03-2009, 02:52 AM
Official TDG Doctor
You can make 600 no prob with a SO pump anyway...
Nate
post #7 of 17 (permalink) Old 02-05-2009, 09:18 PM
What are sparkplugs
ICEMAN3005's Avatar
If you do go hot rod P get the 200/200 fass my 150/150 can keep up WOT, PSI drops below 10
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #8 of 17 (permalink) Old 02-05-2009, 09:35 PM
2nd Gen Guru
Yeah but look at the amount of fuel your dumping in the cylinders...
post #9 of 17 (permalink) Old 02-05-2009, 10:05 PM
What are sparkplugs
ICEMAN3005's Avatar
Ya when I get the wife truck done this monday the diesel goin in the garage gettin all the fliuds changed, oil leak fix, fuel gauge fixed not reading correctly, drive line issue fixed and a bigger fass, I haven't even been able to get past 2/3 throttle ever since I installed injectors and hot rod P. : I did a 5.8 second 0-60MPH three weeks ago and that was only half throttle.
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #10 of 17 (permalink) Old 02-06-2009, 07:40 AM
ppump conversion trucks been running the fass 150 with no issues a buddy has a 02 and did this just added a bigger spring from fass and makes over 600 no fuel issues even the 1000hp fuel only trucks been running the 150. might want to check out your filters and lines
01quadcab is offline
p pump dzl04 5.9L Cummins (Pre 1994) 10 12-17-2007 03:13 PM
P-Pump DBogo 5.9L Cummins (1998.5-2002) 15 09-10-2007 06:19 PM
P-pump wrongway Whats Been Sold 6 03-22-2007 11:25 PM
ACCEL 110GPH Fuel Pump/Lift Pump maxxis_mudder Whats Been Sold 0 12-10-2006 03:24 PM
BOOST-A-PUMP burnsout fuel pump!!!!! koolkat812 2003-2007 6.0L Power Stroke 26 09-02-2005 01:21 AM
