Brakes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Taylor34, this thread has received 22 replies and been viewed 1608 times.
post #1 of 23 (permalink) Old 02-06-2009, 03:19 AM Thread Starter
Taylor34's Avatar
Brakes
ok extremely dumb question...ive always taken my trucks in to get the brakes done and im tired of paying 75 dollar labor so im gonna do it myself only one thing ive never done it i know i got to take off the caliper and what not but how do i depress the pistons or whatever before i put the new ones on and how do i take the old pads off
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #2 of 23 (permalink) Old 02-06-2009, 04:28 AM
bmoeller's Avatar
It isn't bad at all.
At least on my '97, it takes a big Torx bit to remove the calipers. Once it is removed, the pads just slip out. Might also be a funny looking anti-rattle clip snapped in place.
To depress the pads, open the bleeder screw (or loosen the banjo bolt) BEFORE pressing the pistons in. I use the old pad that sits against the pistons as an aid to clamp against. I use a big C- clamp to press the pistons in. Or, you can buy a cheap tool that will do the same thing.
http://www.mytoolstore.com/kd/kdbrak07.html
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 23 (permalink) Old 02-06-2009, 04:29 AM
cowboytw13's Avatar
You need a C clamp, then use the old shoe so you don't damage the piston. Then just put the clamp in the middle of the piston, and just depress the piston in the entire way. It's pretty easy, here's a pic.
cowboytw13 is offline
post #4 of 23 (permalink) Old 02-06-2009, 04:48 AM Thread Starter
Taylor34's Avatar
alright thanks guys i read on the net that the caliper bolts can be taken out with 14mm socket
Taylor34 is offline
post #5 of 23 (permalink) Old 02-06-2009, 04:57 AM Thread Starter
Taylor34's Avatar
how about the rear brakes is there anything special to do with the emergency brake setup
Taylor34 is offline
post #6 of 23 (permalink) Old 02-06-2009, 06:35 AM
no it's pretty much the same but when compressing the caliper back off the bleeder screw as it's bad for the master to have fluid forced back that way. thats why my grandpa told me and he ran a shop for many many years
01quadcab is offline
post #7 of 23 (permalink) Old 02-06-2009, 07:05 AM Thread Starter
Taylor34's Avatar
alright thanks guys
Taylor34 is offline
post #8 of 23 (permalink) Old 02-07-2009, 02:07 PM
2nd Gen Guru
Mopar1973Man's Avatar
Hmmm...
I never heard of the bled screw thing...
But I normally pry the in-board shoe slightly to remove the caliper and then use a large pair of channel locks and squeeze the piston back in.
But so far I've got 140K miles on my truck and NEVER change brake pads yet... I figure I'll go all the way to 200K mile before its due...
Now I've had to reuild the rear to caliper because of sticking pistons.
This bring up anothe topic. Maske sure you change you brake fluid every 30K miles. You be suprised on how my trash and junk gets into the claipers and wheel cylinders.
After 28K miles... Brake fluid does get rather ugly...
Mopar1973Man is offline
post #9 of 23 (permalink) Old 02-07-2009, 04:16 PM
cowboytw13's Avatar
Well...must be nice to have an engine brake...
post #10 of 23 (permalink) Old 02-07-2009, 04:28 PM
Official TDG Doctor
hccumminssmoke's Avatar
i replaced everything in Dec 06 and then pads in July 08
Nate
hccumminssmoke is offline
Under 26K with Air Brakes?? 07duramax Medium and Heavy Duty 7 02-05-2009 09:47 PM
Bad Brakes emerica454 General Ford Truck and Excursion 10 12-02-2007 04:16 AM
Brakes BEN1234 Diesel Conversion 10 01-05-2007 07:09 AM
brakes? DieselDan 1994-2003 7.3L Power Stroke 3 05-25-2006 07:43 PM
Big brakes koolkat812 2003-2007 6.0L Power Stroke 24 04-30-2006 02:58 AM
