Trouble with Sbend Clutch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 8 replies and been viewed 580 times.
post #1 of 9 (permalink) Old 02-09-2009, 01:33 AM Thread Starter
JLWelding's Avatar
I just got truck back from shop and clutch wont release. You have to start in gear and basically have to syncronize to shift gears. Truck will begin to move with pedal 1" from floor.Vibration at about 40mph to 55mph. This Mechanic works for a Dodge Dealership he should know what he is doing I would think.
Part #MU13-1.25CON O 350HP Clutch 750 ft lbs
JLWelding is offline
post #2 of 9 (permalink) Old 02-09-2009, 01:54 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Have a friend who had the same problem as you but he did it himself. When he installed the hydraulic upgrade he took that plastic piece off the end big no no its suppose to stay on and the first time you push the clutch it will snap off inside something about keeping the piston from over extending i hear
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 9 (permalink) Old 02-09-2009, 11:18 PM Thread Starter
JLWelding's Avatar
Vibration fixed,driveshaft 180 out
post #4 of 9 (permalink) Old 02-09-2009, 11:35 PM
2nd Gen Guru
Mopar1973Man's Avatar
Well here is my install of a stock master/slave cylinder...
http://mopar.mopar1973man.com/tips/c...tch%20-Hyd.htm
Mopar1973Man is offline
post #5 of 9 (permalink) Old 02-10-2009, 01:14 AM Thread Starter
JLWelding's Avatar
Will have new master and slave cylinder with adjustment install hopefully tomorrow. Hope this will fix shifting problem.
post #6 of 9 (permalink) Old 02-10-2009, 01:16 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
If that doesnt work your shift tower might need adjusted friend just informed me that might be why mine is a pita to get in reverse.
post #7 of 9 (permalink) Old 02-10-2009, 02:19 AM
lbdodge24v's Avatar
I know the feeling about trying to get one into reverse. Mine likes to use the grind method, lol. Real attention getter.
02 Dodge Ram CTD, 6 spd., HMR Street Drag Clutch, Raptor 150, Edge Drag Comp, Smarty, Injectors, aFe air intake, 2 in leveling kit, 4 in exhaust, and 3 guages-Fuel Pressure, Boost, and EGT's.
The Toy a Jummins!!
lbdodge24v is offline
post #8 of 9 (permalink) Old 02-10-2009, 02:33 AM Thread Starter
JLWelding's Avatar
Didnt know there was a adj. for shifter. I have to go from 3rd to rev. to get in gear. Thought that was just the way it was.
post #9 of 9 (permalink) Old 02-10-2009, 02:37 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I can get mine in reverse from nuetrual but i dont like that so i usually do 3rd to reverse to.
Upgraded Clutch Fork w/South Bend Clutch??? Stinger23 1994-2003 7.3L Power Stroke 5 09-07-2010 10:50 PM
Clutch trouble ? Elwood 7.3L and 6.9 IDI (Pre 1994) 5 01-10-2009 11:40 PM
Clutch Trouble bdizzel 5.9L Cummins (1998.5-2002) 7 01-13-2008 11:23 PM
a/c trouble WBV06CTD 5.9L Cummins (2003-2007.5) 2 04-09-2006 05:58 PM
