Fuel Pressure Gauge Install Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Badoes, this thread has received 11 replies and been viewed 2581 times.
post #1 of 12 (permalink) Old 02-09-2009, 05:00 AM Thread Starter
Badoes's Avatar
Send a message via AIM to Badoes Send a message via MSN to Badoes Send a message via Yahoo to Badoes Send a message via Skype™ to Badoes
My Brother and I were installing a fuel pressure Gauge in my 01 earlier today, and are having a problem getting it to register fuel pressure on the gauge. It is a Mechanical Gauge. When we first started the engine up after the gauge was set up, the gauge showed a fuel pressure of apprx 5-10. when we took the truck out for a quick test drive, the gauge stopped working. We've bled both the line running from the isolator valve to the banjo bolt on the bottom of the fuel filter, and the line running from the isolator valve to the gauge in the cab. We When the engine is running we were getting a tiny trickle of Antifreeze (which is what we used in the line from the valve to the gauge) out of the end of the line.
Just looking for some ideas on what possible causes might be, Or if there are any how too guides on installing the mechanical gauge.
~Daniel
01 Dodge 3500 5.9 Sport Dually, smarty, LUK clutch, NV4500, bilstein shocks, 285 toyo ATs, 5" straight pipe exhaust, Silencer ring...missing
Dually Club Member #24
Badoes is offline
post #2 of 12 (permalink) Old 02-09-2009, 02:07 PM
cowboytw13's Avatar
First off, I"m not so sure it's a good idea to be running your fuel pressure gauge off of the bottom of the fuel filter. The Ideal place to hook up your pressure gauge is off of the Injection pump With a special banjo bolt. Here is the one that Diesel Manor sells:
http://dieselmanor.com/dm_products/DM-DBBLT.asp
If you don't want to buy that, I'd at least put it on the top of the filter housing in the test port on the injection pump side. Putting it on the bottom could get it clogged with dirt.
Just my $.02
cowboytw13 is offline
post #3 of 12 (permalink) Old 02-09-2009, 03:03 PM Thread Starter
Badoes's Avatar
Just my $.02
The install directions we used were from the diesel manor and showed the banjo bolt getting plugged into the bottom of fuel filter. It was for an electrical gauge so im wondering if its different with a mechanical gauge.
~Daniel
Badoes is offline
post #4 of 12 (permalink) Old 02-09-2009, 04:50 PM
cowboytw13's Avatar
I'm assuming that your running the Autometer gauges, just a guess. When I installed mine (ISSPRO), they told me to hook into the injection pump, but I installed an Airdog 100 Fuel pump, and just hooked into the new line that I ran. I would try either hooking into the injection pump, or the test ports on the top of the fuel filter. If it still doesn't work, your sending unit might be shot. Also, where is the sending unit mounted? Sometimes engine vibration can hurt them.
post #5 of 12 (permalink) Old 02-09-2009, 05:18 PM Thread Starter
Badoes's Avatar
I have the Dipricol Optix gauges. We installed the isolator on the driver's side of the truck. I attached a pic of where we put it.
~Daniel
Badoes is offline
post #6 of 12 (permalink) Old 02-09-2009, 08:23 PM
Supporting Vendor
The most common issue I see is that the isolator piston has bottommed out. Try removing the antifreeze-filled tube (gauge side) from the isolator, then use a small (and NOT sharp) rod to push the diaphragm/piston fully to the other end of travel, then fill that side of the isolator with as much antifreeze as you can get in there, then reassemble the tube. Up at the gauge, remove the tube and fill the remaining tube volume with antifreeze (it helps to have a syringe for this part), then reinstall.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 271k miles
10 ISSPRO Prototype Performax™ gauges in Pillar & Overhead pods & sitting on dash, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps, Swamps tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
32' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
2000 VW Jetta TDI - Kerma tune, Der Chimera Stage II Clutch
NRA member and certified firearms instructor, GOA Life member, IDPA member
Michael is offline
post #7 of 12 (permalink) Old 02-09-2009, 11:21 PM
hawkeye213's Avatar
I also installed the isolator on my truck. I am constantly having to redo the isolator like mentioned above. Undo gauge side and push the piston back down and refill the isolator. it usually last about 2 weeks and then have to redo. Live Oak another poster here mentioned once that he thought it had to do with the outdoor temp ranges. Mine here range from 70 one day to 20 the next. I am hooked into the schraeder valve on the IJ pump. I am going to change mine over soon to directly into fuel line and get rid of isolator like mopar does.
hawkeye213 is offline
post #8 of 12 (permalink) Old 02-09-2009, 11:32 PM
2nd Gen Guru
Mopar1973Man's Avatar
Personally I skipped the isolator and used a needle valve. But thats' just me...
Mopar1973Man is offline
post #9 of 12 (permalink) Old 02-10-2009, 12:35 AM
If you saw a trickle of antifreeze, then you have a leaky joint. I had all kinds of problems with the tubing/fittings leaking on mine. I changed the fittings and tubing multiple times. I finally used grease gun hose on mine and it is holding pretty well.
2001.5 Ram 2500 Quad Cab, HO, 6 speed, 4.10's, RV275 injectors, Quadzilla XZT+, AFE 4" Exhaust, ISSPRO Gauges (EGT, FP, Boost), K&N Air Filter, Raptor 100 Fuel Pump, 1/2" line with AN fittings to the factory fuel filter, 6AN fittings from fuel filter to injection pump.
dave2001 is offline
post #10 of 12 (permalink) Old 02-14-2009, 07:18 PM
Heavy Equip. Is My Life
I see air bubbles in the top line.
Russ
Late '99 F-350 7.3l 6sp 2wd Aftermarket dually kit 186,000mi STOCK
'99 Dodge 3500 24v 47re QCLB 4x4 DRW 131,000mi Straight-piped
'97 Chev 3500 6.5TD Auto-OD ECLB 4x4 DRW 199,000mi 4" exh. turbo to bumper
Deeslfxr is offline
Fuel pressure gauge install dieselpower1966 1994-2003 7.3L Power Stroke 7 05-05-2008 04:25 PM
Another fuel pressure gauge question. King0581 1994-2003 7.3L Power Stroke 2 03-19-2008 10:50 PM
Help, fuel pressure gauge TowRig 1994-2003 7.3L Power Stroke 20 08-31-2007 02:53 PM
Fuel Pressure Gauge Install TowRig 1994-2003 7.3L Power Stroke 3 08-15-2007 02:40 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
