99 Missing and Blowing White or Blue Smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99Cummins24V, this thread has received 10 replies and been viewed 7236 times.
post #1 of 11 (permalink) Old 02-13-2009, 09:31 PM Thread Starter
When I am about 1/2 throttle or more the Engine starts missing and blowing blue or white smoke out the exhaust. The more I get into it the worse it gets. What would cause this?
99Cummins24V is offline
post #2 of 11 (permalink) Old 02-13-2009, 11:57 PM
JLWelding's Avatar
Check for codes.Bad as I hate to say it sounds like a dead VP 44.
JLWelding is offline
post #3 of 11 (permalink) Old 02-14-2009, 12:55 AM Thread Starter
Hey thanks. Not what I wanted to hear but good to know now then when i am on the other side of the state
post #4 of 11 (permalink) Old 02-14-2009, 03:28 AM
JLWelding's Avatar
Yea white smoke and missing a tell all sign. But still need to check for codes. I dont think you can do the key switch for codes on a 99. Need to fine a scanner. Let us know what you fine.
post #5 of 11 (permalink) Old 02-14-2009, 05:55 AM Thread Starter
I will let you know. I have a buddy with a scanner so thats not a problem
post #6 of 11 (permalink) Old 02-14-2009, 06:05 PM
Heavy Equip. Is My Life
When did you change fuel filter last? Check fuel pressure also.
Russ
Late '99 F-350 7.3l 6sp 2wd Aftermarket dually kit 186,000mi STOCK
'99 Dodge 3500 24v 47re QCLB 4x4 DRW 131,000mi Straight-piped
'97 Chev 3500 6.5TD Auto-OD ECLB 4x4 DRW 199,000mi 4" exh. turbo to bumper
Deeslfxr is offline
post #7 of 11 (permalink) Old 02-15-2009, 02:29 PM
2nd Gen Guru
Mopar1973Man's Avatar
Fuel presure?
http://mopar.mopar1973man.com/tips/c...-pump-daig.htm
Filter?
http://mopar.mopar1973man.com/tips/c...l%20filter.htm
Error Codes?
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
This will verify it...
Mopar1973Man is offline
post #8 of 11 (permalink) Old 02-16-2009, 09:04 PM Thread Starter
I change my fuel filter every 10,000 miles and I just Changed it two days ago and the missing and hesitation went away. but it is still throwing a code I have never even heard of. P1693 DTC Detected In PCM (Code sets when ECM Detects Code In JTEC Controller (PCM)).
post #9 of 11 (permalink) Old 02-16-2009, 11:38 PM
JLWelding's Avatar
1693 means there is another code in, I belive the pcm. Your buddies scaner should have picked it up.
post #10 of 11 (permalink) Old 02-17-2009, 01:59 AM
2nd Gen Guru
Yeap... The P1693 means there is more error codes present...
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-05-2009 11:11 PM
Puking Coolant, Now Blowing White Smoke! DINOONE 2008-2010 6.4L Engine Tuner Forum 20 02-13-2009 11:46 PM
97 6.5 changed ip now its blowing white smoke? 97GMC6.5Z71 6.5L Diesel Engine 8 01-03-2008 01:29 AM
HELP!!! Its sputterin and blowing white smoke Matty69 1994-2003 7.3L Power Stroke 12 05-10-2006 04:18 AM
