Edge hot unlock - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SparkyLV, this thread has received 14 replies and been viewed 8274 times.
post #1 of 15 (permalink) Old 02-17-2009, 04:54 AM Thread Starter
Indecisive
Send a message via AIM to SparkyLV
Thumbs up Edge hot unlock
Can I get some feed back on how you like the hot unlock if you have it on your juice with attitude or any other edge products?
How hot does it run egt wise
and what are the boost numbers like?
How much faster or harder does it pull than level 5?
Thank you
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #2 of 15 (permalink) Old 02-17-2009, 01:15 PM
level 6 made the egts a little hotter and the boost about 33 then my waste gate blows close and there is a lot of power though out your rpm rang edge has the hot unlock for $50 right now
cummins-dodge is offline
post #3 of 15 (permalink) Old 02-17-2009, 03:22 PM Thread Starter
Indecisive
Yeah that is why I was thinking about getting it?
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #4 of 15 (permalink) Old 02-18-2009, 01:20 PM
2nd Gen Guru
Mopar1973Man's Avatar
Like on the Edge comp it basically changes the defuel limit there is no change in fueling other than it fuel all the way to 3,200 RPM instead of 2,700 RPM's
Mopar1973Man is offline
post #5 of 15 (permalink) Old 02-19-2009, 06:25 AM Thread Starter
Indecisive
I bought it!
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #6 of 15 (permalink) Old 02-20-2009, 04:21 AM
let me know how it works for you. Mine is kind of down right now and having computer issues so my hot unlock didn't do any good yet.
01quadcab is offline
post #7 of 15 (permalink) Old 02-24-2009, 04:35 AM Thread Starter
Indecisive
IT went really well!!
Pulls a lot than 5!
you can tell by the fuel pressure compared to 5.
Worth the money.
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #8 of 15 (permalink) Old 02-24-2009, 09:46 PM
99 cummins
customdeluxe78's Avatar
do you mean we wont see any power difference with the comp below 2,700? i want to get mine updated but if my power wont be any better below 2,700 i wont even bother. i may just be misunderstanding you, if i am, excuse my ignorance.
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #9 of 15 (permalink) Old 02-26-2009, 05:04 PM Thread Starter
Indecisive
Well there is the no advertised power gains, it just fuels a much more aggressive curve all the way to 3200 rpm compared to the other ones that fuel less but start tapering off at 2700.
Get it while it is on sale well worth it and you can feel the truck build harder.
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #10 of 15 (permalink) Old 02-26-2009, 05:23 PM
Local Cummins nut
MOPAR MAN's Avatar
Send a message via AIM to MOPAR MAN
IMO it is the same as pwr lvl 5 untill you hit 2700 RPM 5 falls on its face ware 6 pulls hard till 3200 rpm. Other than that there the same. But that last 500 RPM can make all the diffrence in the world when your pulling or racing.
00 Ram 2500 4x4 5-spd, Balanced & blueprinted, O-ringed & studded CR Head W/head work, Billet Hamilton HD Big Stick Cam pushrods & Valve springs, Coated pistons & barings, all ARP studs & bolts, S&B CAI & AF1 Intake horn, Equal tube length header, 5" Turbo back Exhaust, Edge Juce W/Attitude (HOT), 120 HP EDM'd Injectors, Custom Garrett GT3788R BB Turbo, FASS 150/150, ValAir DD W/3600Lb PP, FluidAmper, Amsoil Bypass, 7" lift, HID's, Cowl Hood, 38.50x14.50x17,
Singles Club Member #244 Riding HIGH Club Member #43
MOPAR MAN is offline
Edge Hot Unlock cowboytw13 5.9L Cummins (1998.5-2002) 9 02-03-2009 02:44 AM
$150 to unlock my SCT SICKS-O 2003-2007 6.0 Tuner Forum 8 12-29-2007 05:43 PM
should i unlock my edge juice w/ att masonjo 5.9L Cummins (1998.5-2002) 11 03-06-2007 01:42 PM
Edge juice hot unlock code masonjo 5.9L Cummins (1998.5-2002) 7 11-24-2006 01:47 AM
How to unlock an SCT Farm_Edition 2003-2007 6.0 Tuner Forum 1 11-08-2006 09:49 PM
