No overdrive, though scanner shows it being commanded - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bobcat698, this thread has received 5 replies and been viewed 700 times.
post #1 of 6 (permalink) Old 02-18-2009, 04:09 AM Thread Starter
99 Dodge 3500 Auto.
Has a full built tranny with Goerend valve body & converter.
Recently, the crank position sensor behind the starter went haywire. I drove it a few days before I had a chance to replace it. The last day I drove it, I lost overdrive.
The tranny would lock/unlock randomly in third, but will not shift into overdrive.
I figured the two MIGHT be related as the crank sensor tells the PCM how many RPM the engine is turning, which I'm sure might have something to do with shift points.
I figured wrong.. I changed the crank sensor and now the truck runs a ton better, but it still won't shift to 4th.
I kept the scanner hooked up while driving it, it shows that 4th gear is being commanded, but it doesn't shift to 4th.
Any ideas?
Thanks in advance.
Bobcat698 is offline
post #2 of 6 (permalink) Old 02-18-2009, 06:34 AM
Ghost
Phily's Avatar
Check the governor pressure, make sure it's in check. I've heard of not have O/D when gov pressure is mess up, I'm yet to see it. Usually when it's off you lose 1 and 2. Also I've never done it yet, but I think you can remove the O/D without the transmission actually coming off. So you could make sure you O/D isn't nuked. They had plenty of O/D problems in stock transmissions, but being yours is Goerand, I dunno. Check for codes too, see if you got any.
Phily is offline
post #3 of 6 (permalink) Old 02-18-2009, 06:36 AM
Ghost
Phily's Avatar
I'm also assuming you have 1 and 2. If not, something is fu-cked in your wiring.
Phily is offline
post #4 of 6 (permalink) Old 02-18-2009, 12:29 PM Thread Starter
I have 1, 2, & 3
post #5 of 6 (permalink) Old 02-18-2009, 06:07 PM
What are sparkplugs
ICEMAN3005's Avatar
check for a blown fuse. Maybe a bad overdrive solenoid located on VB two square looking things, one is lockup solenoid other is overdrive solenoid with a wire coming out of it, right next to governor solenoid. Faulty overdrive switch or overdrive switch module located under dash. or worst case lower vavle body malfunction.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #6 of 6 (permalink) Old 02-20-2009, 04:45 AM
Ghost
Phily's Avatar
No updates? Must have been a fuse
What's going on? You got this going into a O/D yet?
Phily is offline
fav tv shows HotSauce2138 The Parking Lot 19 02-26-2008 11:59 PM
favorite TV shows cope junkie The Parking Lot 14 01-07-2008 10:29 PM
Where Are All The Truck Shows Scubba Canada 1 11-02-2007 11:41 PM
Running Out Of Fuel Before Gage Shows Empty Cajunsuperduty 2003-2007 6.0L Power Stroke 13 08-03-2007 01:47 PM
What happened to the ol' tv shows..! blackcloudCTD95 The Parking Lot 10 06-06-2007 02:28 AM
