Fuel pressure! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SparkyLV, this thread has received 10 replies and been viewed 995 times.
post #1 of 11 (permalink) Old 02-19-2009, 06:30 AM Thread Starter
Indecisive
Send a message via AIM to SparkyLV
Fuel pressure!
So if you read my other thread my factory lift pump was on the out! 9-11 psi while idle, and under 9 if any load more than quarter throttle!
Changed the fuel filter and nothing.
So called Dan over at FASS because he helped me out on all my ford FASS issues and he was able to cut me a great deal on the DDRP.
Install it today and every thing goes well, fuel pressure now at idle is 15 to 17 on the edge juice and under heavy throttle goes down to 10-11.
Is there any other way to keep the pressure up during acceleration other than a bigger FASS? Is there another fuel filter other than that one right there by the motor?
Does any one make a high flow fuel filter for these trucks?
Or any other ideas?
Thank you
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #2 of 11 (permalink) Old 02-19-2009, 12:28 PM
relocate the pump with a vulcan big line kit so it doesn't have to suck the fuel so much just supply it. other than that a fass without filters
01quadcab is offline
post #3 of 11 (permalink) Old 02-19-2009, 02:39 PM
2nd Gen Guru
Mopar1973Man's Avatar
FASS DDRP has all the orignal lift pump problems...
* Too far from the tank.
* Uses too small of plumbing and banjo bolts.
I'm not sure but I heard they only put out like ~60 GPH...
Compared to a AirDog Raptor at 100 GPH which comes with all plumbing fitting etc...
Mopar1973Man is offline
post #4 of 11 (permalink) Old 02-19-2009, 06:52 PM Thread Starter
Indecisive
Well what about this vulcan big line kit?
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #5 of 11 (permalink) Old 02-19-2009, 07:07 PM Thread Starter
Indecisive
So i looked and this is what I need!
This kit, 1/2 inch or 3/8 fitting though moparman?
http://www.vulcanperformance.com/Dra...p/vpps9804.htm
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #6 of 11 (permalink) Old 02-19-2009, 07:17 PM
Official TDG Doctor
hccumminssmoke's Avatar
There is no reason to buy that Vulcan Kit and the FASS DDRP....just buy a FASS 95 w/ or w/o filters, FASS 150 w/ or w/o filters, or a PureFlow Raptor, or an Air Dog 100, or 150 w/ filters...it'll be cheaper in the long run...the Air Dogs are on sale for 499 right now and the Raptor is only 399 w/ everything you need...Im getting my Raptor in tomorrow, I havnt had any experience w/ Pure Flow Tech.
Nate
hccumminssmoke is offline
post #7 of 11 (permalink) Old 02-19-2009, 07:20 PM Thread Starter
Indecisive
I already got the FASS DDRP straight from Dan at FASS so it was to good of a deal to pass up?
Why even buy at 95 series FASS? might as well go tot he 150! and its like 570 dollars?
So with what I am out on this DDRP and that vulcan line kit would be like 300 dollars?
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #8 of 11 (permalink) Old 02-19-2009, 07:21 PM Thread Starter
Indecisive
Plus if a FASS is no perfect they do not work right? I have owned 2 previous fords 6.0 and both had them.
And a buddy of mine has a FASS on his 2003 dodge and it was a pain to get perfect.
-Steve-
BITD- 7241
2007 5.9
SparkyLV is offline
post #9 of 11 (permalink) Old 02-19-2009, 11:25 PM
Official TDG Doctor
Well this is how i see it I *believe* (dont have time to check) that the DDRP is like 30% more flow then stocker...so I would think it would be like putting the Vulcan on the stock pump...if you put any kind of pusher on a stock when the stock dies it doesnt matter whether or not the pusher is working good or not...If thats the case then you would run a good risk of killing the VP...How much HP are you going for? I *think* again no time to look that I have read no more then 350 on these...
Also check this out:
http://www.vulcanperformance.com/product-p/reldd.htm
This relocates the DDRP to the rail which would draw better out of tank...
Nate
post #10 of 11 (permalink) Old 02-20-2009, 04:20 AM
the best bet to try and make it work is the big line kit as it will not have to draw the fuel as much and have a better time pushing the fuel. get the 1/2" lines so if later you do go with a 150 you have the fittings all there. I still run my fass through the factory filter for the fuel heater as it gets pretty dang cold here.
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
$100 Off DJ's FUEL+ - Fuel Pressure Intensifier MOMBENZ Supporting Vendors Forum 3 12-13-2006 01:49 AM
anyone doing fuel pressure or oil pressure skinz0021 General Dodge Discussion 7 08-19-2006 02:42 PM
