running brake fluid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgetheonlytrk, this thread has received 11 replies and been viewed 1393 times.
post #1 of 12 (permalink) Old 02-25-2009, 12:37 AM Thread Starter
running brake fluid
what do yall think bout running used brake fluid as a additive n my fuel
dodgetheonlytrk is offline
post #2 of 12 (permalink) Old 02-25-2009, 12:58 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
I think...wait....I know brake fluid eats plastic, rubber, and anything else that is petroleum based...
Do you not like your truck?...or are do you just want to blow it up and hand it over to the insurance company?
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #3 of 12 (permalink) Old 02-25-2009, 01:00 AM
cowboytw13's Avatar
I'd have to agree. If you ask anyone on this forum what additive to run, they will tell you: two stroke oil.
cowboytw13 is offline
post #4 of 12 (permalink) Old 02-25-2009, 01:11 AM
TANK'S 250's Avatar
Images: 38
Ashless 2 stroke oil
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #5 of 12 (permalink) Old 02-25-2009, 01:29 AM
Official TDG Doctor
hccumminssmoke's Avatar
I dont run 2 stroke oil...I run Power Service products...
Nate
hccumminssmoke is offline
post #6 of 12 (permalink) Old 02-25-2009, 11:45 PM Thread Starter
i didnt no all that well im glad i ask i was just wanting to get rid of it. u can run used motor oil tho rite
post #7 of 12 (permalink) Old 02-25-2009, 11:51 PM
TANK'S 250's Avatar
Images: 38
I would n't do that either,...same reason,...it will leave an ash
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #8 of 12 (permalink) Old 02-26-2009, 03:39 AM Thread Starter
dame that weird i no a guy that has a cr n he does a 50/50 mix n he has 100,000 miles on it i just figure i would ask u guy to see what yall say.i guess i will just go with 2 stroke oil
post #9 of 12 (permalink) Old 02-26-2009, 03:44 AM
TANK'S 250's Avatar
Images: 38
There are exceptions to every rule,...but is it worth risking...that is the real question you have to ask your self....
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #10 of 12 (permalink) Old 02-26-2009, 03:47 AM
Gone Fishin...
merlin5577's Avatar
You can run used oil, if its super filtered for debris and water, and you keep it under 5% mixed with diesel, then you shouldnt have a problem. And make sure there is NO coolant in it.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
Brake fluid dissappearing powerstroke7.3 1994-2003 7.3L Power Stroke 2 11-26-2007 10:50 PM
Brake Fluid Trbotime 2003-2007 6.0L Power Stroke 14 11-09-2007 02:29 AM
Running 100% atf fluid as fuel???????? jebsurf 1994-2003 7.3L Power Stroke 4 04-12-2007 02:22 AM
Drain ALL Brake Fluid in PSD, Bad or Ok? Muddin 1994-2003 7.3L Power Stroke 11 08-24-2006 12:49 PM
Synthetic Brake Fluid Armkb General Ford Truck and Excursion 2 02-26-2006 12:38 AM
