engine revs up on its own??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hin0031, this thread has received 12 replies and been viewed 10381 times.
post #1 of 13 (permalink) Old 03-01-2009, 12:27 AM Thread Starter
Have 2002 dodge 2500 24 vavle and have noticed that while backing up sometimes, engine will rev up to about 2300 rpm's, then come down and kill engine. only happens once and a while. if i try to restart right away, it does not restart, but if i wait 25 sec. it will fire up with no prob. any suggestions??? have 121k on now
hin0031 is offline
post #2 of 13 (permalink) Old 03-01-2009, 01:53 AM
Official TDG Doctor
hccumminssmoke's Avatar
Check for codes and then get back to us...
Nate
hccumminssmoke is offline
post #3 of 13 (permalink) Old 03-01-2009, 02:13 PM
2nd Gen Guru
Mopar1973Man's Avatar
I agree...
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
Mopar1973Man is offline
post #4 of 13 (permalink) Old 03-01-2009, 06:56 PM
Ghost
Phily's Avatar
A bad APPS will cause the engine rev, I've seen it a few times. But never as high 2300RPM.
Phily is offline
post #5 of 13 (permalink) Old 03-02-2009, 09:44 PM Thread Starter
the codes it is throwing is 1691 and 1693
hin0031 is offline
post #6 of 13 (permalink) Old 03-02-2009, 09:48 PM
Official TDG Doctor
1691 isnt very good man...thats 'Internal fuel injection pump failure. Low power, engine
derated, or engine stops.' 1693 is just a companion code...did these come off of the ODO or did you use an actual scanner?
Nate
post #7 of 13 (permalink) Old 03-03-2009, 01:07 AM Thread Starter
off the dash, just put new pump in 25000 miles ago and dodge will not back up there work or product
hin0031 is offline
post #8 of 13 (permalink) Old 03-03-2009, 01:24 AM
Official TDG Doctor
Get it checked with a Code Reader...Did you take it to a Stealership?! and they didnt warranty the pump?? Sounds fishy too me...Is your truck stock? Is the pump tapped? it could just be a glitch in the IP...Idk also if it is possible but I have heard of the ODO retaining codes so heck that 1691 could have very well been from when you did your pump work...but idk
Nate
post #9 of 13 (permalink) Old 03-03-2009, 01:24 PM Thread Starter
they put it in under warranty 25000 miles ago and says it is out of warranty. i found out that they have put a reman pump in and not a new one as i thought. i have had codes checked recently and they never showed these codes. these have come up in the last week or so. truck is stock.
hin0031 is offline
post #10 of 13 (permalink) Old 03-03-2009, 05:20 PM
Of Course
P1691 - Fuel Injection Pump Controller Calibration Error Internal fuel injection pump failure. Low power, engine derated, or engine stops.
That Guy is offline
Lumpy revs... imported_BillM2004 5.9L Cummins (2003-2007.5) 0 05-06-2008 08:18 PM
Rough running, revs curtall 2003-2007 6.0L Power Stroke 5 11-24-2007 11:13 PM
Revs between shifts imported_06F450 2003-2007 6.0L Power Stroke 10 10-21-2007 02:28 PM
Possible to measure engine deck specs on engine in truck? Trulyvintage 7.3L and 6.9 IDI (Pre 1994) 3 06-16-2007 04:10 AM
Idle revs up for no apparent reason... waynard 1994-2003 7.3L Power Stroke 13 12-15-2005 01:54 PM
