RPM Drop Quick - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 1 replies and been viewed 455 times.
post #1 of 2 (permalink) Old 03-01-2009, 05:05 PM Thread Starter
JLWelding's Avatar
RPM Drop Quick
I got a new one for ya, was adjusting valves today and checked injector hold down bolts and found #6 was loose and made about 2 rounds on bolt. Ok then when I started truck everything is normal I get in go down the road about 5 miles and go to slow down and i clutch it and rpm drop quick faster than normal. And on up shift rpm drop quick, whats up with that?
JLWelding is offline
post #2 of 2 (permalink) Old 03-05-2009, 02:30 PM
2nd Gen Guru
Mopar1973Man's Avatar
Did you have fuel bleeding past a injector from a loose hold down?
Mopar1973Man is offline
oil pressure drop off cajunguy359 Medium and Heavy Duty 21 05-03-2008 06:19 PM
2in Drop Shackles imported_Stroker01 1994-2003 7.3L Power Stroke 1 01-19-2008 07:17 PM
Why did my MPG drop? JeffBrouillette 5.9L Cummins (2003-2007.5) 10 08-15-2007 03:53 PM
2nd gen K&N drop in ash_flat_diesel Whats Been Sold 1 05-14-2007 02:56 AM
2/4 Drop htsht 2003-2007 6.0L Power Stroke 1 08-03-2005 03:15 PM
