oil pan gasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgetheonlytrk, this thread has received 2 replies and been viewed 7418 times.
post #1 of 3 (permalink) Old 03-02-2009, 07:40 PM Thread Starter
oil pan gasket
how hard is it to change. can u just unbolt it n pull it out
dodgetheonlytrk is offline
post #2 of 3 (permalink) Old 03-05-2009, 02:31 PM
2nd Gen Guru
Mopar1973Man's Avatar
From what I've heard you need to lift the engine a few inches with a hoist to gain enough room between the crank and the cross member.
Mopar1973Man is offline
post #3 of 3 (permalink) Old 03-05-2009, 08:22 PM
REMOVAL
1. Disconnect the battery negative cables.
2. Raise vehicle on hoist.
3. Remove transmission and transfer case (if equipped) from vehicle, refer to Transmission and Drivetrain.
4. Remove flywheel.
5. Disconnect starter cables from starter motor.
6. Remove starter motor and transmission adapter plate assembly. WARNING: HOT OIL CAN CAUSE PERSONAL INJURY.
7. Drain the used engine oil. Dispose of the used oil properly.
8. Install the oil pan drain plug with a new sealing washer and tighten to 60 Nm (44 ft. lbs.) torque.
9. Remove oil pan bolts, break the pan to block seal, and lower pan slightly and remove oil suction tube fasteners.
Fig. 149
10. Remove oil pan and suction tube (Fig. 149).
CLEANING
Remove all gasket material from the oil pan and cylinder block sealing surfaces. Extra effort may be required around Joint areas. Clean oil pan and flush suction tube with a suitable solvent.
INSPECTION
Inspect the oil pan, suction tube, and tube braces for cracks and damage. Replace any defective component. Inspect the oil drain plug and drain hole threads. Inspect the oil pan sealing surface for straightness. Repair any minor imperfections with a ball-peen hammer. Do not attempt to repair an oil pan by welding.
INSTALLATION
1. Fill the T-joint between the pan rail/gear housing and pan rail/rear seal retainer with sealant. Use Mopar Silicone Rubber Adhesive Sealant or equivalent.
2. Place suction tube in oil pan and guide them into place (Fig. 149). Using a new tube to oil pump gasket, install and tighten the suction tube bolts by hand. Starting with the oil pump inlet bolts, tighten the bolts to 24 Nm (18 ft. lbs.) torque. Tighten the remaining tube brace bolts to 24 Nm (18 ft. lbs.) torque.
3. Starting in the center and working outward, tighten the oil pan bolts to 24 Nm (18 ft. lbs.) torque.
4. Install the flywheel housing assembly with the starter motor attached and tighten bolts to 60 Nm (44 ft. lbs.) torque.
5. Connect starter motor cables.
6. Install transmission and transfer case (if equipped). Refer to Transmission and Drivetrain.
7. Lower vehicle.
8. Install battery negative cables.
9. Fill the crankcase with new engine oil.
10. Start engine and check for leaks. Stop engine, check oil level, and adjust, if necessary.
The Following User Says Thank You to sstockton For this addition to TDG:
dodgetheonlytrk (03-06-2009)
Oil pan gasket Rob 5.9L Cummins (Pre 1994) 5 03-01-2009 07:14 PM
Pan gasket Caos56 1994-2003 7.3L Power Stroke 1 01-30-2009 03:09 AM
Oil Pan Gasket Diesel dude 7.3L and 6.9 IDI (Pre 1994) 1 01-20-2008 08:23 PM
Head Gasket time should I stud it and A/M Gasket it? cdooguy 2003-2007 6.0L Power Stroke 7 04-26-2007 04:36 AM
Gasket time... BogginF350 2003-2007 6.0L Power Stroke 1 10-17-2005 03:45 AM
