vp44 questions? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01_24valve, this thread has received 13 replies and been viewed 1615 times.
post #1 of 14 (permalink) Old 03-04-2009, 01:28 AM Thread Starter
01_24valve's Avatar
vp44 questions?
so i have a 2001 VP44 and it has 140000 on the stock pump that is about to eat it. I am looking to upgrade and was surfing the net looking at pumps. what do you think about the hot rod VP44? or what about the monster VP44? what are the differences in the two pumps? are there any advantages and disadvantages to each of the pumps?
01_24valve is offline
post #2 of 14 (permalink) Old 03-04-2009, 01:28 AM Thread Starter
01_24valve's Avatar
PS i am also running a 150 Airdog
post #3 of 14 (permalink) Old 03-04-2009, 01:34 AM
Singles Club Member #34
Send a message via Yahoo to dslrunner86
i just lost mine at 120000 but that was because of my apps going out and the previous owners bad choice of wire taping. Ive havent heard much of the monster vp44 but ive herd the hotrod 44 is ok. Im having mine re-done at the local injection shop costs a lil more but it being built the way i want it so its worth it.
1999 dodge 2500 24v ext cab long bed 4x4, nv4500 w/a LUK clutch, 5" straight pipe to 6" stacks, Red Oak Diesel VP44, holley black lift pump and big line kit, edge juice w/ attitude, RV275's, Modified intake horn and plate, Lock-N-Stich'd 53 Block, BHAF, no silencer, 06' 17" rims w/ 295/70/17 nitto terra grapplers.
Walking V & HILBILLY INC.
dslrunner86 is offline
post #4 of 14 (permalink) Old 03-04-2009, 02:27 AM
Official TDG Doctor
hccumminssmoke's Avatar
The Monster shouldnt be on a Daily Driver IMO...idk how they are w/ electronics...i know they make great HP on fuel only...but I think that a Hot Rod pump is the BIGGEST waste of money!!!! you can make 600hp on a SO pump so why would you need to buy a hot rod? From the dyno results that I have seen when tapped the Hot Rod Pump looses hp...I also know that the guy at 'monstervp.com' or something like that (he has vids on youtube) will warrenty the pump but when it dies he says that you starved it of fuel and will not replace it...I have an Industrail Injection SO VP44 and I like it right well...but its your truck....
Nate
hccumminssmoke is offline
post #5 of 14 (permalink) Old 03-04-2009, 03:35 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Why do Hot Rod pumps make bad daily drivers? I know a kid who runs one with 100 horse sticks and a FASS with programming by Quadzilla Adrenaline.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #6 of 14 (permalink) Old 03-04-2009, 03:50 AM
Official TDG Doctor
I know several people that drive them everyday too...but they rob mpg's...its like having a SO pump with a Drag Comp on 100% of the time...its just a lot to drive around with on the daily, haul with, it can be done but its a pita...
Nate
post #7 of 14 (permalink) Old 03-04-2009, 05:13 AM
just get a good so vp 44 and you will be happy.
01quadcab is offline
post #8 of 14 (permalink) Old 03-04-2009, 02:16 PM
2nd Gen Guru
Mopar1973Man's Avatar
Nate
Funny... My Edge Comp is wide open 5x5 every day...
Yeap... A stock SO pump will perform better with electronics that a HotRod pump... Not to mention you can tone it down if needed (snow and ice, slick conditions,etc)
Mopar1973Man is offline
post #9 of 14 (permalink) Old 03-04-2009, 06:24 PM Thread Starter
01_24valve's Avatar
my edge stays 5x5 too! i have plans to take this it a light sled pickup so that is why i am considering the bigger pump and i like to race. it sounds like everyone is against the oversize VP44. has anyone very ran one?
post #10 of 14 (permalink) Old 03-04-2009, 06:31 PM
Hot Rod Farm Boy
I turned 21
Don't rule out simply switching to a HO VP44. Seems to me like that would bridge the gap. But would there be issues with electronics?
Logan
Hot VP44 or Blue Chip's VP44 Mad Dog Cycles 24 Valve Performance 12 05-03-2009 01:38 AM
vp44 dodgeman00 Whats Been Sold 3 03-11-2009 01:41 PM
Vp44...... blackcloudCTD95 Dodge - Modification instructions, Product installs and Tech Articles 1 01-12-2009 06:36 PM
Need a new VP44 Allan05F350 5.9L Cummins (1998.5-2002) 2 07-12-2007 05:55 PM
