Hey - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by O2CUMMINS, this thread has received 4 replies and been viewed 712 times.
post #1 of 5 (permalink) Old 03-04-2009, 05:13 PM Thread Starter
O2CUMMINS's Avatar
Send a message via Yahoo to O2CUMMINS
Hey
Hey ya'll, I just wanted to drop in and say hey. I have not been posting due to the fact of being deployed. I am not able to get on here much, but I will as time permits.
2002 Cummins 24v 6speed Grandrock 6" Aussies, : ADRENALINE , BHAF with k&n intake tube, Autometer pyro, boost & Fuel pressure gauge, 100 HP sticks, FASS, new injection pump. Valair DD and 62/65/12 charger.
:smoke
O2CUMMINS is offline
post #2 of 5 (permalink) Old 03-04-2009, 07:19 PM
Be safe over there, when are you due back?
The Following User Says Thank You to sstockton For this addition to TDG:
O2CUMMINS (03-09-2009)
post #3 of 5 (permalink) Old 03-08-2009, 05:30 PM Thread Starter
O2CUMMINS's Avatar
I am not sure. I could be here as little as 7mo or up to over a year.
:smoke
post #4 of 5 (permalink) Old 03-09-2009, 05:02 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Thank you. Keep your head down and your gun clean. Godspeed.
Logan
Do Or Die Garage Experiment
cummins power is offline
The Following User Says Thank You to cummins power For this addition to TDG:
post #5 of 5 (permalink) Old 03-11-2009, 03:01 PM
2nd Gen Guru
Mopar1973Man's Avatar
I agree with that comment...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
O2CUMMINS (03-14-2009)
