air filter question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hotrodx199, this thread has received 11 replies and been viewed 1541 times.
post #1 of 12 (permalink) Old 03-05-2009, 01:02 AM Thread Starter
air filter question
So i'm getting a $10 intake filter from a friend of mine. It's oiled just like a K&N filter, and it's a pretty decent size. Although it won't bolt up because it's a little small and the hose is too big to bolt on. But if i managed to make it bolt on, would there be any differences between the intake filter vs the stoke airbox w/ K&n filter? Every thing is stock except for exhaust and drop in filter.
Hotrodx199 is offline
post #2 of 12 (permalink) Old 03-05-2009, 01:11 AM
Official TDG Doctor
hccumminssmoke's Avatar
are you leaving it open? no air box? I have always been told that you need to keep oiled filters in boxes, and only have dry open...but idk fo sho...
Nate
hccumminssmoke is offline
post #3 of 12 (permalink) Old 03-05-2009, 02:26 PM
2nd Gen Guru
Mopar1973Man's Avatar
The K&N is going to be a PITA...
Dry filters do so much better and last much longer... I'm running a $40 dollar BHAF and it got over 100K miles now and 5 years later still going. I never got to wash, oil, blow off, vacuum, etc...
Why mess with junk...
Mopar1973Man is offline
post #4 of 12 (permalink) Old 03-06-2009, 04:07 AM Thread Starter
do u know where i can get a BHAF at?
post #5 of 12 (permalink) Old 03-06-2009, 05:32 AM
napa or ask vendors on here check out moparmans site he has part numbers for lots o brands of them
01quadcab is offline
post #6 of 12 (permalink) Old 03-06-2009, 07:31 AM
Ghost
Phily's Avatar
Right there^
Just go to Napa # 2790
or you could by original equipment: Fleetguard # AH19037
Both damn good, I'd go with whatever is cheapest.
Phily is offline
post #7 of 12 (permalink) Old 03-06-2009, 05:07 PM
2nd Gen Guru
Here is cheap...
http://www.vulcanperformance.com/Sea...sp?Search=BHAF
BHAF for $39
Outwears pre-filre for $31
post #8 of 12 (permalink) Old 03-23-2009, 04:29 PM
I've got a cylinder K&N air filter that is attached directly to the hose & its wide open in the engine compartment. Yeah, I have to clean it every 6 months or so but other than that I just take it off when I change the oil & tap it on smoething to get any debris out. Why do I go to the extra trouble? Because when its clean, it'll suck in more air than just anout anything else out there, including the BHAF.
wadecool is offline
post #9 of 12 (permalink) Old 03-23-2009, 05:05 PM
thats just what they tell you, but it also lets in many more particles. There are better choices out there and what would help you is a pre filter for it help you not have to knock and abuse the filter. now when you tap it off do you add more oil after doing so? If not then your loosing your filtering capability because the dirt and debris is held by the oil
post #10 of 12 (permalink) Old 03-23-2009, 08:35 PM
2nd Gen Guru
Wow... Now I heeard everything... I got a filter minder in the end of my filter and in 100K miles it never moved... But i test it often and it still works fine... I've got ZERO filter restriction... The only thing I got to was is the outerwears... But mine wore out...
Air Filter Question jennamax 2003-2007 6.0L Power Stroke 0 05-11-2007 01:01 AM
AFE stage 2 filter question Extended Power 2003-2007 6.0L Power Stroke 1 02-07-2007 03:09 AM
Oil Filter question goodriddance 2003-2007 6.0L Power Stroke 3 12-18-2006 12:15 AM
Air Filter Question HighTQCummins General Dodge Discussion 13 08-30-2006 06:14 PM
Oi Filter question. CellFishRacing 2003-2007 6.0L Power Stroke 1 03-02-2006 03:06 PM
