injector pump or electrical? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acegreaser, this thread has received 9 replies and been viewed 1533 times.
post #1 of 10 (permalink) Old 03-07-2009, 01:55 PM Thread Starter
2000 24v when you floor engine with no load smokes right away like pump is not advancing correctly.Like the 12v when they were cold.No miss at idle or high rpm when engine is increased normal.Under load engine has normal power than just looses all power and boost.Then if you let up on accelerator and step down again boost and power comes back and the cycle starts all over again.I changed lift pump still the same.188,000 mi on truck.
acegreaser is offline
post #2 of 10 (permalink) Old 03-07-2009, 06:10 PM
cowboytw13's Avatar
Have you checked it for codes? Also are you running gauges, mainly fuel pressure, and what color is the smoke?
cowboytw13 is offline
post #3 of 10 (permalink) Old 03-07-2009, 07:04 PM
did you put on a factory replacement? how is the fuel filter?
01quadcab is offline
post #4 of 10 (permalink) Old 03-07-2009, 07:15 PM
JLWelding's Avatar
APPS maybe. When you said letup on pedal then on it again sounds like it makes contact again.
JLWelding is offline
post #5 of 10 (permalink) Old 03-08-2009, 01:15 PM Thread Starter
Smokes white like timing is off.Like the early 12v when the engine was cold.Fuel filter was changed and new factory lift pump.when engine looses boost you can feather the throttle and you can barely hear engine rpm change with the throttle but absolutely no power or boost until you completly let off the step down again.No smoke during this whole process.Could it be TPS assy?But if it was wouldn't my trans drop out of lock up and O.D.
post #6 of 10 (permalink) Old 03-08-2009, 05:36 PM
O2CUMMINS's Avatar
Send a message via Yahoo to O2CUMMINS
Thats what my truck did when the IP went out. Run it for codes and see what you come up with.
2002 Cummins 24v 6speed Grandrock 6" Aussies, : ADRENALINE , BHAF with k&n intake tube, Autometer pyro, boost & Fuel pressure gauge, 100 HP sticks, FASS, new injection pump. Valair DD and 62/65/12 charger.
:smoke
O2CUMMINS is offline
post #7 of 10 (permalink) Old 03-08-2009, 11:10 PM
JLWelding's Avatar
No mention of white smoke in first post, I think your singing the vp44 blues.
post #8 of 10 (permalink) Old 03-09-2009, 01:39 AM
2nd Gen Guru
Mopar1973Man's Avatar
I bet money if you checked for error codes JL Welding is going to be right while your seeing P0216 error code... Which is typeical when white smoke is present. (lack of timing)
But What cause this failure??? Hmmmm....
I bet if you check your fuel pump is dead or dieing...
Check for error codes...
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
Fuel pump tesing...
http://mopar.mopar1973man.com/tips/c...-pump-daig.htm
Do you have a fuel pressure gauge?
http://mopar.mopar1973man.com/person...ges/gauges.htm
But if the VP44 is shot here is how to change it...
http://mopar.mopar1973man.com/tips/c...44-replace.htm
Mopar1973Man is offline
post #9 of 10 (permalink) Old 03-11-2009, 01:12 AM Thread Starter
codes present P0500,P0216,P0230,P1694,P1693.Thanks for all the help i guess i'm changing the IP.
post #10 of 10 (permalink) Old 03-11-2009, 02:53 PM
2nd Gen Guru
Now why did the IP fail? You better find out oor you'll be doing it again...
P0216 error code is wear error cdoe cause by lack of fuel volume and pressure...
Injector pump f-350 The Parking Lot 0 12-16-2007 05:05 PM
injector pump in Dieselfreak77 5.9L Cummins (1998.5-2002) 4 11-04-2007 11:24 PM
Injector pump ??? redneckcummins 5.9L Cummins 12 Valve (1994-1998.5) 3 04-02-2007 02:40 PM
injector pump HELP!!!!!!!!PLEASE!!!!!!!! don53wood 6.5L Diesel Engine 3 01-24-2007 11:13 PM
