exhaust brake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by heathww, this thread has received 5 replies and been viewed 939 times.
post #1 of 6 (permalink) Old 03-12-2009, 09:46 AM Thread Starter
Exclamation exhaust brake
i have an 01 with 4 inch exhaust,tri disc converter,edge comp,rebuilt trans with shift kit,i installed an in line exhaust break but was woundering how to get more out of brake the brake is a pac brake exhaust kit i was thinking about a pressure lock but its a little spendy
heathww is offline
post #2 of 6 (permalink) Old 03-12-2009, 01:43 PM
converter lock up system like so
http://store.summitracing.com/partde...5&autoview=sku
or you can do a manual switch just make sure to pay attention to what your doing when using it
01quadcab is offline
post #3 of 6 (permalink) Old 03-12-2009, 02:59 PM Thread Starter
sorry to mention i do have the torc lock but i was told if i haul heavy loads i should have the pressure lock
heathww is offline
post #4 of 6 (permalink) Old 03-13-2009, 04:20 AM
that would of helped earlier. So your brake is not working that well, or whats the problem?
post #5 of 6 (permalink) Old 03-13-2009, 08:41 AM Thread Starter
i guess my main question is that do i really need the pressure lock my exhaust brake works great but i have been told the pressure loc is needed to protect the torc converter
heathww is offline
post #6 of 6 (permalink) Old 03-14-2009, 12:04 AM
If you have an upgraded valvebody, upgraded torque converter which i see you have, and a billet input shaft you will be fine. You only need the pressure lock if you didn't have a shift kit for the valvebody or if you didn't upgrade your valvebody. The auto lock can also benefit you too because you can program your lockup speed and unlock speed.
cumminsdude2001 is offline
Exhaust Brake gon2sea 5.9L Cummins 12 Valve (1994-1998.5) 7 02-21-2008 03:49 AM
Exhaust Brake??? kev94mx 2008-2010 6.4L Power Stroke 3 01-16-2008 12:56 AM
exhaust brake sklo Duramax 2004.5-2005(LLY) 1 05-02-2007 02:35 AM
6.7 Exhaust Brake 07duramax 6.7L Cummins (2007.5-2011) 5 02-24-2007 01:27 AM
Exhaust Brake Farmboy162005 2003-2007 6.0L Power Stroke 1 01-09-2007 06:05 AM
