Turbo Timer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 6 replies and been viewed 927 times.
post #1 of 7 (permalink) Old 03-13-2009, 09:51 PM Thread Starter
JLWelding's Avatar
Turbo Timer
How does a turbo timer work? Where do you plug it in at.
JLWelding is offline
post #2 of 7 (permalink) Old 03-14-2009, 09:15 PM Thread Starter
JLWelding's Avatar
anybody
post #3 of 7 (permalink) Old 03-14-2009, 11:22 PM
Official TDG Doctor
hccumminssmoke's Avatar
What kinda timer is it? Like one with a Juice w/ Attitude?
Nate
hccumminssmoke is offline
post #4 of 7 (permalink) Old 03-15-2009, 01:16 AM Thread Starter
JLWelding's Avatar
I did not see the timer I was walking by when it shut off and I asked the man how much it cost and he said 250.00. I thought they only came with a controler. I just assumed by the cost it was a single unit and wondered where and how to hook up. Thanks
post #5 of 7 (permalink) Old 03-15-2009, 01:22 AM
ClutchIt97's Avatar
go to isspros website. i had one of theirs on my truck. it was on the truck when i got it. its a box and i'm not sure 100% how they work just when you shut the key off it kills power to everything but the truck stays running until the truck is down to 300 degrees. it uses a regular pyro probe for that part
97 12 valve, 5 speed, 700cc scheid injection pump with a 5k gov. spring, scheid 5x.013 injectors, Vulcan Performance boot kit, II 66/74/14, cnc port, balanced crank, o-ringed head, a-1 h-11 head studs, bored .20 over, 7 angle valve job, FASS 200, 21 degrees timing, Titanium retainers, Hardened keepers, Mahle pistons, aem air filter, southbend clutch, lowered 3", and isspro gauges
ClutchIt97 is offline
post #6 of 7 (permalink) Old 03-16-2009, 02:00 PM
2nd Gen Guru
Mopar1973Man's Avatar
Sorry for the late reply... I've been gone to fire Academy...
But a turbo timer is a electronic timer that keeps the engine running after to shut the key off and removed for a set amount of time to allow the turbo to cool properly.
So instead of sitting in the truck waiting the 2-3 minutes for a turbo to cool you can shut the key off and jump out and the engine will remaining running for the set time. Most systems are tamperproof. So if someone thinks they can steal the truck it will die if they try...
So it hooks up to several things don't ask me but ignition leas, brake sense (guessin') and a few others...
Mopar1973Man is offline
post #7 of 7 (permalink) Old 03-16-2009, 09:52 PM
ClutchIt97's Avatar
mine wasnt a timer it was hooked up to a pyro probe and the truck had to get down to 300 degrees
Turbo Timer JLWelding Supporting Vendors Forum 1 03-12-2009 01:12 PM
turbo timer 08powersmoke 2008-2010 6.4L Engine Tuner Forum 3 02-05-2009 04:24 PM
Turbo Timer surfdunn General Ford Truck and Excursion 6 12-21-2007 04:56 PM
Turbo Timer 06f250sd 2003-2007 6.0L Power Stroke 2 02-25-2007 08:57 AM
Turbo Timer fuzzys69 2003-2007 6.0L Power Stroke 6 10-06-2005 02:29 AM
