high pitch squeal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by outlaw1_gt, this thread has received 6 replies and been viewed 4793 times.
post #1 of 7 (permalink) Old 03-14-2009, 12:19 AM Thread Starter
high pitch squeal
well i have a problem the other day i put a 3 piece manifold on and 4inch magnaflow exhaust. start it up sounds good. drive it there is a squeal when the turbo start to spool up. and also sqeals when i pull exhaust brake on.. seems like it is coming from the wastegate actuator. any suggestions????
1999 ram 2500 cummins turbo diesel, 5 speed, exhaust brake, quadzillia xzillaraider 120 stacked with superchips d-box, k&n filter, glowshift gauges, tripple pillar pod, fuel pressure, egt and boost, muffler delete pipe, boost elbow, mia silencer ring, airdog 150
outlaw1_gt is offline
post #2 of 7 (permalink) Old 03-14-2009, 01:02 AM
Check your turbo for shaft play.
post #3 of 7 (permalink) Old 03-14-2009, 03:52 AM Thread Starter
shaft play seems good and it never did it before i changed the manifold.
post #4 of 7 (permalink) Old 03-14-2009, 06:00 AM
Sounds just like the issue I am having, I have a squeal that happens wHEN I should hear the turbo spooling up. It is more of a shrill sound then squeal though it is definitely quite loud though. I have checked the turbo and can't find anything physically wrong with it. I have checked the oil lines yet. Im thinking it is my wastegate though I need to figure out how to check that. Anybody want an 01 quad cab short bed 133k for 9500? It has an airdog 100 and brand new tires. Oh and a small turbo issue and 0216 code for a year and a half now.
veritas42 is offline
post #5 of 7 (permalink) Old 03-14-2009, 03:12 PM Thread Starter
bump
post #6 of 7 (permalink) Old 03-14-2009, 10:16 PM Thread Starter
tigtened manifold bolts again and squeal gone
post #7 of 7 (permalink) Old 03-16-2009, 02:01 PM
2nd Gen Guru
Mopar1973Man's Avatar
I was going to say its sound like a drive pressure leak somewhere on the manifold before the turbo... But you got it!
Mopar1973Man is offline
High Pitch Whistle Noise prolxstang89 1994-2003 7.3L Power Stroke 9 01-27-2009 02:22 AM
HELP!!! High pitch turbo noise bigbirdF250 2003-2007 6.0L Power Stroke 1 04-11-2007 12:02 AM
Tow/Haul squeal gtxpooch 5.9L Cummins (2003-2007.5) 0 03-11-2007 03:59 PM
turbo squeal lubeowner 2003-2007 6.0L Power Stroke 7 03-29-2006 11:51 AM
Loud Squeal ??? Morpheus cycles 2003-2007 6.0L Power Stroke 14 01-18-2006 08:57 PM
