Rear Disc Conversion - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sstockton, this thread has received 9 replies and been viewed 4913 times.
post #1 of 10 (permalink) Old 03-17-2009, 03:29 AM Thread Starter
Just curious if anyone knows what it takes to switch to rear discs on a 2000. Is it just rotors and calipers, or do I need a different axle housing or shafts? Also I'm assuming I will need to change the master cylinder or install a lower pressure residual valve as well.
post #2 of 10 (permalink) Old 03-17-2009, 04:07 AM
Ghost
Phily's Avatar
i dunno
but....
I got quotes on parting out my truck and Dana 80's with rear brakes only go for 700 bucks. Just something to consider. The proportioning valve will need switched out too. I don't know if the 2000 have dual piston calipers. But I can tell you my 2002 brakes much better than my 98 ever did. And my 2002 weighs more than 1000lbs more. If you have single piston calipers up front I would just try and do axles out of a 01 or 02 depending on if you want CAD or not.
Phily is offline
post #3 of 10 (permalink) Old 03-17-2009, 05:55 AM
there is a guy with a 00 that is getting ready to give his truck back to the bank. his has a posi and mine doesn't. I was wondering the same thing. If I could just swap axles, discs, drums, and rotors. Same dana 70 on both same gears just diff brakes.
01quadcab is offline
post #4 of 10 (permalink) Old 03-17-2009, 06:03 AM
D_B
EGR makes the complete kit.
I think it's around $1,000.
http://www.egrbrakes.com/index-main.htm
Pretty much bolt on with everything you need.
DB
1999 Dodge Ram 2500 LWB, Intense Blue, 5spd,
4:10's, all kinds of goodies and doodads!
NRA Lifer
D_B is offline
post #5 of 10 (permalink) Old 03-17-2009, 05:25 PM
for that price you can just go buy a whole rear axle out of a wreck and put it in
post #6 of 10 (permalink) Old 03-17-2009, 05:40 PM
Ghost
Phily's Avatar
For a 1000 bucks you can swap axles with me!
Phily is offline
post #7 of 10 (permalink) Old 03-18-2009, 12:53 AM
joush is offline
The Following User Says Thank You to joush For this addition to TDG:
sstockton (03-18-2009)
post #8 of 10 (permalink) Old 03-19-2009, 01:11 PM
2nd Gen Guru
Mopar1973Man's Avatar
Just easier to swap the entire axle than trying to piece it together.
Mopar1973Man is offline
post #9 of 10 (permalink) Old 03-19-2009, 09:00 PM Thread Starter
Yeah, but then I have to find a matched axle. Getting brackets and calipers isn't really all that hard. With the kit available, it isn't really that much work to switch. Provide it is a quality kit and everything fits as it should.
post #10 of 10 (permalink) Old 03-20-2009, 01:30 AM
Swapping to disc brakes is probably takes just as long as swapping to an axle with disc brakes already. The only reason I would swap in a new axle with disc brakes is if you have a D70 and you found a good deal on a D80.
joush is offline
Rear disc brakes cummins kid General Dodge Discussion 5 03-17-2009 11:05 AM
2001 2500 4x4 Rear Drum to Disc Brake Conversion and other mods? 6thFrame 5.9L Cummins (1998.5-2002) 4 01-07-2008 11:28 PM
Osb Rear Disc Brake Conversion CrashFireRescue 1994-2003 7.3L Power Stroke 2 12-12-2007 04:54 PM
Rear Disc Conversion TurboTPI 1994-2003 7.3L Power Stroke 11 11-05-2007 09:09 PM
Rear Disc Brakes for 10.25 Squatch General Ford Truck and Excursion 1 07-22-2006 03:04 PM
