Time to fix the truck - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 11 replies and been viewed 1493 times.
post #1 of 12 (permalink) Old 03-20-2009, 11:09 PM Thread Starter
Well I need a new turbo, the bearings are going out. Also I need new balljoints. I want to put in some heavy duty joints rather than oem. What are some good ball joints to buy? Also I know replacing the ball joints are a pain, but has anybody done a write up on it? Also do I need to replace upper and lower, balljoints, at the same time? P.S. If you have an hy 35 for sale pm me.
veritas42 is offline
post #2 of 12 (permalink) Old 03-21-2009, 01:55 AM
Forget the HY, if your gonna stay with just a stock replacement get an HX35,
stay away from HY35 because they are to restrictive, and plus if you ever want to upgrade parts on the HX like a compressor wheel or a turbine housing, you can through HTT(hightechturbo). I had all my frontend parts including the trac bar replaced with MOOG problem solver chassi parts. I bough mine from carquest, i dunno where else you can get them. They have a lifetime replacement guarentee, they are exspensive but worth it, and they are greasable.
cumminsdude2001 is offline
post #3 of 12 (permalink) Old 03-21-2009, 07:21 PM
2nd Gen Guru
Mopar1973Man's Avatar
I agree... HX35 turbo is a must better turbo for stock. They will handle up to 35 PSI worth of boost stock.
Mopar1973Man is offline
post #4 of 12 (permalink) Old 03-21-2009, 07:52 PM Thread Starter
With the hx 35 to I have to change my downpipe etc...
post #5 of 12 (permalink) Old 03-21-2009, 11:51 PM
Nope, it bolts right in. it was stock on all trucks up to 01 then the 01 and 02 autos got the hy35.
As for the 35psi boost thing, the map of a turbo is more than just psi boost. The hx35 can actually make up to 47psi boost and still be within its map. However, it can only provide enough air for the cummins to be running at about 1100rpm at that boost level. If you're really winding it out, the turbo falls out of its map at around 3000rpm and 24psi boost. For a stock truck, I think the hy is fine. It will spool faster. The main difference is the hx will provide better exhaust flow.
The Following User Says Thank You to sstockton For this addition to TDG:
veritas42 (03-22-2009)
post #6 of 12 (permalink) Old 03-22-2009, 12:39 AM
bmoeller's Avatar
If you have 4.10 gears, both the HY and HX in stock form are VERY restrictive on the top end.
"Obama = Hoax and Chains"
bmoeller is offline
post #7 of 12 (permalink) Old 03-22-2009, 01:21 AM Thread Starter
So it is bolt on with having the 01 auto? I am going to call dtt see if they can rebuild my hy.
01 2500, quad cab, 2wd, auto, 132k, turbo rebuilt good as new by htt , and 0216 code for 1 1/2 years now. Airdog 100 fuel system after 3 stock lift pumps.
post #8 of 12 (permalink) Old 03-22-2009, 03:53 AM
Better off with HTT. They have all the upgrades for the HX35 you might have a better shot with them.
post #9 of 12 (permalink) Old 03-22-2009, 06:21 AM
don't waste the cash on the hy get an hx bolts right in and works better you can upgrade it to a hybrid if you want just don't stay with the 9cm housing your wasting time
01quadcab is offline
post #10 of 12 (permalink) Old 03-22-2009, 05:02 PM Thread Starter
Sorry, I meant HTT, not dtt. Ya I am gonna call them on Monday and see if maybe the will do a swap or something, see what I can work out. My main issue right now is money, I need to get off as cheaply as I can. I have a tranny out on another car, and two vehicles including this one needing balljoints.http://www.autopartswarehouse.com/se...h=2001%20Dodge I was thinking of getting a moog ball joint from here. Has anybody used auto parts warehouse? They are pretty much the same bj's that carquest carries but cheaper.
When is it time to lemon law my truck? pjsrubicon 6.7L Cummins (2007.5-2011) 31 02-15-2008 12:47 AM
First time at the track in the truck.... BigRed97 1994-2003 7.3L Power Stroke 7 09-10-2007 09:24 PM
New Job = Quality Time w/ Truck genie144 1994-2003 7.3L Power Stroke 2 06-19-2007 02:17 PM
First time with truck at pulls??? 03HDPOWER Sled Pulling 4 08-10-2006 03:01 PM
Truck time Rich The Parking Lot 6 08-14-2005 03:50 AM
