2002 H.O. long block swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by shane2loco4u, this thread has received 3 replies and been viewed 746 times.
post #1 of 4 (permalink) Old 03-23-2009, 05:43 PM Thread Starter
Nathan Petry
I have a 2002 dodge 1 ton 24 valve. The engine started to knock a few months ago, pulled the oil pan off and checked all bearings and wrist pins, but can not find any problems. I have talked to local shops about rebuilding the motor and have been quoted anywhere from $4,000 to $8,000. For less than that I can find a running engine or long block but can not seem to find an H.O. My question is: is there and internal difference in an H.O. and a non H.O. motor, if so will a non H.O. motor work in the truck and bolt up to a 6 speed transmission. Thanks, Nathan
shane2loco4u is offline
post #2 of 4 (permalink) Old 03-23-2009, 07:39 PM
only difference is compression ratio. It will bolt up and work fine, just make sure you use the SO pump.
01quadcab is offline
post #3 of 4 (permalink) Old 03-24-2009, 03:24 AM
2nd Gen Guru
Mopar1973Man's Avatar
That knock could be a injector problem... Or a VP44 problem (timing issue)...
Just to give you something to try to save you a buck or two... (Shrug smiley)
Mopar1973Man is offline
post #4 of 4 (permalink) Old 03-24-2009, 02:01 PM Thread Starter
Nathan Petry
Thanks for the imput, when I put the oil pan back on and fire it up is there a way I can check the fuel pump myself? I thought it was in the bottom end because I put a stethascopeon on the block, but the motor is so noisy I could be mistaken.
6.7 long block and transmission moparguy2004 Whats Been Sold 2 02-27-2009 09:06 PM
Hpop, Injectors, Intake Parts Long Block Macktruckdriver Whats Been Sold 10 05-01-2008 11:20 PM
7.3L parts and rebuildable long block!!!!! Macktruckdriver Whats Been Sold 35 02-06-2008 05:43 PM
Long Block dlopp 1994-2003 7.3L Power Stroke 2 03-29-2007 06:12 PM
12v long block jarhead Whats Been Sold 2 09-10-2006 03:10 PM
