Diff fluid change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 19 replies and been viewed 1983 times.
post #1 of 20 (permalink) Old 03-29-2009, 04:33 PM Thread Starter
Diff fluid change
I am gonna change the fluid out of my rear diff, and I was wondering if there is a gasket for the diff? As far as I know there you make a gasket out of rtv. If anybody know's otherwise please let me know, thanks ahead of time for the help.
01 2500, quad cab, 2wd, auto, 132k, turbo rebuilt good as new by htt , and 0216 code for 1 1/2 years now. Airdog 100 fuel system after 3 stock lift pumps.
veritas42 is offline
post #2 of 20 (permalink) Old 03-29-2009, 04:42 PM
no gasket just rtv. I get the permatex small tube that goes in the caulking gun and it works great.
01quadcab is offline
The Following User Says Thank You to 01quadcab For this addition to TDG:
veritas42 (03-29-2009)
post #3 of 20 (permalink) Old 03-29-2009, 09:10 PM
Don't forget the limited slip differental addative.
cumminsdude2001 is offline
post #4 of 20 (permalink) Old 03-29-2009, 10:14 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
When I use the RTV I use brake cleaner fluid after I have cleaned the gasket surface. I let the RTV set up like they say I think it is 10 min then torque them down.
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #5 of 20 (permalink) Old 03-29-2009, 10:17 PM
Ghost
Phily's Avatar
He might not need it, if the clutches are worn out enough. That additive just makes the clutches slip easier. If he does the fluid change and doesn't notice any chatter than you are better off leaving it out.
Phily is offline
post #6 of 20 (permalink) Old 03-29-2009, 10:42 PM
JLWelding's Avatar
Dont use to much rtv I am having trouble with trans. having silica in oil sample they think rtv may have made this problem.
JLWelding is offline
post #7 of 20 (permalink) Old 03-29-2009, 11:15 PM
Ghost
Phily's Avatar
Ya alot of people love to gob RTV on things. I just spread it evenly with my finger, it makes your fingers a mess, but helps insure you don't end up with big globs of RTV in your oil.
Phily is offline
post #8 of 20 (permalink) Old 03-30-2009, 01:36 AM
Well he don't have that much more miles than me and I put the lucas stuff in. Said it didn't need any addatives and a week later I started getting a chatter. I went to carquest and got the addative and the noise was gone. There is a reason your suppose to use it.
post #9 of 20 (permalink) Old 03-30-2009, 02:19 AM
I agree RTV has given me fits so if I can I buy a gasket. I think RTV requires a very clean surface and for the cure time to be just right, and if you don't clean out the rear end super good it will run down the sealing surface and cause a leak.
Bill
5" SS Tip
post #10 of 20 (permalink) Old 03-30-2009, 06:29 PM
Ghost
Phily's Avatar
Yes I know, but some people think it's always needed and it actually helps the aids in traction.
Phily is offline
What the best diff fluid? WasGas 2003-2007 6.0L Power Stroke 75 04-10-2009 02:33 PM
diff fluid change? 04-F350 2003-2007 6.0L Power Stroke 3 04-17-2008 02:34 AM
Tranny and Diff replacement fluid Burner718 1994-2003 7.3L Power Stroke 0 12-29-2007 04:56 AM
Rear diff. fluid TSGS69400 2008-2010 6.4L Power Stroke 5 12-12-2007 09:39 AM
rear diff fluid??? DIESEL73 1994-2003 7.3L Power Stroke 3 04-10-2007 10:32 PM
