Torque Converter Wrench???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdude2001, this thread has received 5 replies and been viewed 7574 times.
post #1 of 6 (permalink) Old 04-01-2009, 12:02 AM Thread Starter
Is there a special wrench to unbolt the TC from the flexplate on a 47RE????? I removed the inspection plate and there is not much room to work with. There must me some kind of special wrench to get up there. NEED HELP PLEASE!!!!!!!!!!!!!!!:
cumminsdude2001 is offline
post #2 of 6 (permalink) Old 04-01-2009, 06:07 AM
you just roll the flex plate and remove the bolts one at a time while turning.
01quadcab is offline
post #3 of 6 (permalink) Old 04-01-2009, 08:31 AM
Ghost
Phily's Avatar
TC bolts aren't really a walk in the park for anything, but with the Cummins you can use a barring tool removing half the stress involved. Make sure you push it forward too when going back in, I've worked on some dodges where I forgot to push the tc all the way forward and ran into a binding issue and had to replace both the tc and input shaft. I like to use red lock tight on the bolts as well, but that's my opinion, not everyone recommends to use it.
Phily is offline
post #4 of 6 (permalink) Old 04-03-2009, 12:03 AM
I'm going to take a guess that you just removed the bottom inspection plate? That works on GM's and such, or at least the older ones, but not on these. There is a torque converter bolt access cover on the other side of the transmission adapter. By the heat exchanger. It is held in place by two 10 or 12mm bolts. Remove that and you will have access. Then I would use a flywheel turner, or barring tool to rotate and access all of the bolts.
I usually loosen them all just a little bit first, then pull them out. don't back them out too much the first time around, or they will catch on the engine/transmission adapter.
Hope this helps.
post #5 of 6 (permalink) Old 04-03-2009, 10:55 PM Thread Starter
Hope this helps.
Thanks Sean. I made some calls the next day and that was it. Ther dodge trannies have that plate just behind the heat exchanger. I had my uncle turn the flywheel with a pry-bar. Had blue loctite on them and will use blue locktite on the new bolts. I removed the flex-plate and installed the new BD flex-plate. I can't believe how tinny the factory one is. If this engine was behind an Allison in a bigger truck i am guessing they would use something better than stamped steel. Thing sounds like sheet metal when you hit it with a wrench.
post #6 of 6 (permalink) Old 04-04-2009, 04:43 AM
yeah they are a little chinsy. the bd flex plate is super strong and you won't have any problems with that unit
silvrcummns is offline
Torque Converter heavyhaller 2003-2007 6.0L Power Stroke 18 12-20-2007 01:28 PM
OBS torque converter imported_whitelightning 1994-2003 7.3L Power Stroke 2 12-02-2007 07:27 PM
Torque Converter Teelo 5.9L Cummins (2003-2007.5) 26 06-07-2007 11:55 PM
Torque Converter 00Excursion General Ford Truck and Excursion 5 05-20-2007 11:03 AM
Torque Converter ??? HELP PLEASE Drrm80 1994-2003 7.3L Power Stroke 7 11-24-2006 03:41 PM
