help..... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by muffdaddysram, this thread has received 8 replies and been viewed 881 times.
post #1 of 9 (permalink) Old 04-02-2009, 01:36 AM Thread Starter
help.....
I got 2001 dodge ram 3500 4x4 diesel. just installed new raptor 150 lift pump.install new ho 245 vp 44 pump,and also apps .all kind of power.when driveing down the road and you let off the pedal then push it back on there is nothing.dead pedal.then it slowly picks up then it jump all the way inn.or if you take off at the lite it dead pedal and then takes off with balls to the wall.codes on the dash is 1693,then it say p done,i run a cornwell scanner it comes up 0216,0602.need help please........
muffdaddysram is offline
post #2 of 9 (permalink) Old 04-02-2009, 02:15 AM
2nd Gen Guru
Mopar1973Man's Avatar
First off put all your information in your signature...
Second off you did the error codes wrong. There should of been 2 P Done's Basically the P PCU displays first and shows a P Done then P ECU displays and P Done then Odometer pos up again... So don't cancel error code reading with the key let it finsh till the Odometer pops up.
P0216 - VP44 is dieing...
P0602 - ECM fueling Calibration error (common for programmers).
Now how much fuel pressure do you have? Because the lift pump might be the cause of the VP44 dieing. So get ready for expensive bill between the lift pump and a VP44 pump. It going to be close $2,000 to do right..
Then on top you going to need a fuel pressure gauge to keep you out of trouble in the future...
Mopar1973Man is offline
post #3 of 9 (permalink) Old 04-02-2009, 02:51 AM
Official TDG Doctor
hccumminssmoke's Avatar
I assume you have a 6 speed?
Nate
hccumminssmoke is offline
post #4 of 9 (permalink) Old 04-02-2009, 10:12 PM Thread Starter
the raptor 150 .18 psi brand new vp 44 and apps. it only say 1693 p done that is it !!!!!
post #5 of 9 (permalink) Old 04-02-2009, 10:40 PM
2nd Gen Guru
Sorry it impossible to have just the P1693... P1693 is a companion code meaning there is MORE code(s) present in the other computer (ECM and/or PCM)...
post #6 of 9 (permalink) Old 04-02-2009, 11:34 PM
Official TDG Doctor
???? 1693 is just a companion code...what rpms run when you hit 'dead pedal'?
Nate
post #7 of 9 (permalink) Old 04-02-2009, 11:36 PM
Official TDG Doctor
The ONLY way to only have 1693 is if you just check in the ODO, b/c not every code will come up in it...I only had 1693 when my Cam Sensor went bad, but I took my SMARTY to it and got other codes...
Nate
post #8 of 9 (permalink) Old 04-03-2009, 12:39 AM Thread Starter
thats the only code.just check it.sometimes at a stop lite,or going down the road.what are some symtems of a fuel shut down relay going bad
post #9 of 9 (permalink) Old 04-03-2009, 12:44 AM Thread Starter
scan codes are 0216 ,602 .everytime i install new vp 44 i get the 216
