Please help!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by oleblue6banger, this thread has received 25 replies and been viewed 1623 times.
post #1 of 26 (permalink) Old 04-04-2009, 04:29 PM Thread Starter
oleblue6banger's Avatar
Exclamation Please help!!!
ok heres the skinny i just got the injector pump and the head gasket replaced. Got the truck back and it is gutless and has pretty good blow by. it has the edge juice with attitude and with it on level 5 it runs like it should stock. IM STUMPED!!!
oleblue6banger is offline
post #2 of 26 (permalink) Old 04-04-2009, 10:16 PM
cowboytw13's Avatar
What is your fuel pressure at? Could be that the lift pump is shot.
cowboytw13 is offline
post #3 of 26 (permalink) Old 04-05-2009, 03:49 AM
i wonder if theshop that installed ur pump and head gasket were out beating the chit out of ur truck before u picked it up , does your turbo sound like its spooling, is there alot of black smoke?
86 1 tonhauler is offline
post #4 of 26 (permalink) Old 04-05-2009, 04:23 AM
JLWelding's Avatar
Thats my first thought is maybe it ran to good after work was done.
JLWelding is offline
post #5 of 26 (permalink) Old 04-05-2009, 04:28 AM
yeah we need more info on what its doing. what are the egt's? does it smoke? what color is the smoke? does eveything look tight and connected under the hood?
check all electrical connections, both intercooler boost tubes, check for fuel leaks. Or just take it back to the shop and ask whats up.
silvrcummns is offline
post #6 of 26 (permalink) Old 04-05-2009, 06:15 AM Thread Starter
yeah everything is connected and tight it threw a code of a turbo boost sensor voltage low is that my MAP sensor? the smoke is fine and normal and egts are normal and the fuel pressure is good, its just gutless the turbos not spooling well but i checked the play in it and it seems to be normal not leaking oil or ne thing its just an all around terd im thinking the map sensor what do you guys think?
post #7 of 26 (permalink) Old 04-05-2009, 02:27 PM
cowboytw13's Avatar
Turbo Boost sensor voltage low is the map sensor. Does it throw that code all the time?
post #8 of 26 (permalink) Old 04-06-2009, 12:35 PM Thread Starter
no i cleared all the codes about 2 days ago, but it hasnt came back on since. it used to come on and go off at different times. last night i was messing with it and with the programmer (edge juice with attitude) turned up to level 5, it doesnt even smoke at all.
post #9 of 26 (permalink) Old 04-06-2009, 03:17 PM
cowboytw13's Avatar
Also, with the turbo not spooling up, I'd check the boots going to and from the intercooler. Probably not the problem, but I'd check anyways.
post #10 of 26 (permalink) Old 04-07-2009, 12:49 PM Thread Starter
yep checked all those last night and all of them were tight. changed the map sensor and still didnt fix it. do you think my box could be fried and screwing the whole truck up? on stock, it wont even pull a hill at 75 it starts to bog down. we are going to look at the box and do some switching with one of my buddies who has the same box and see what that does. btw we put a smarty on level 8 on top of the edge juice and the smarty seems to be doing ok.
