Question on 1693 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeffybuilt, this thread has received 5 replies and been viewed 1141 times.
post #1 of 6 (permalink) Old 04-07-2009, 06:09 PM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Question on 1693
Ok guys, I just read a thread about the P1693, which I thought I was fairly familliar with. Heres what I thought....I get the 1693 all the time, and had thought that it was a consequence of having my Comp on the truck, as the truck sees something 'interfering' so it sets the 1693.
BUT I havnt run a scanner to it for a while, so your saying that there could be more codes to come up with the scanner BASED OFF the 1693 code? Well, if thats the case than I am going out now to buy a new scan tool....
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #2 of 6 (permalink) Old 04-07-2009, 08:42 PM
2nd Gen Guru
Mopar1973Man's Avatar
Ok... Let get some thing squared up here...
The P1693 code will only show up using the "Key Trick" method. This is to alert the owner/user that there is other codes present so keep going. The P1693 code normally doesn't show up in portable scanners because the scanner read the error codes differently. But take a look at my updated write up with video and this will explain a bit more of it...
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
Jeffybuilt (04-07-2009)
post #3 of 6 (permalink) Old 04-07-2009, 08:58 PM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Thanks for that Mike.
I went to your link and almost started laughing....because the codes you had posted on there were P0500 and P0236, and those are both mine too.(I just ran the scanner on it...)
Ok, I get how that works now. Now my question concerns the P0236. From what I understand, when you get that code, the procedure is to check the map sensor for the +5 volts, which I did, and mine is fine...I am thinking that when I put that stupid smoke switch in, I had turned the key when it wasn't hooked up and that is when it set the code. I believe thats what happened because right after I started the truck at that time, the CEL was on. After shutting it off and restarting, the CEL was off and has not come on since than. So basically the computer stored that one, and the P1693 was showing in the OD window to tell me to SCAN the thing, and that told me about the P0236...Sound right?
So all should be well, and I guess I just need to stop being an idiot and remember to reconnect things before I turn my ignition on. :
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #4 of 6 (permalink) Old 04-08-2009, 12:33 AM
2nd Gen Guru
P0236 is from the smoke switch being on too long... The computer can figure out how you drive miles and miles with 20 PSI boost and never fall at idle... Computer is totally confused...
P0500 - Typical speed sensor error...
post #5 of 6 (permalink) Old 04-09-2009, 03:10 AM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Ha ha, the funny thing is, I have NEVER used the switch except for the day I installed it, and yesterday when I was messing with the scanner! Oh dang, Im going to make myself sound even more like an idiot....Its possible I have simply had it in the "ON" position, instead of the "OFF" one...as in hooked up the toggle backwards! That is pretty funny, I'll have to break out the volt meter and check all that tomorrow. But I got a good laugh out of your reply!
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #6 of 6 (permalink) Old 04-09-2009, 03:59 AM
2nd Gen Guru
That's how I got the error above... I forgot which position was normal MAP and smoke MAP...:
Catarpillar 1693 DieselPower Medium and Heavy Duty 27 04-20-2011 05:32 PM
Caterpillar 1693 Specs + Pics? Flamex Medium and Heavy Duty 30 03-15-2011 03:00 PM
CAT 1693 - Specs and the story on them? kblackav8or Medium and Heavy Duty 48 11-01-2010 05:02 AM
Odometer Code 1693 snuffywells 5.9L Cummins (1998.5-2002) 12 08-11-2007 01:22 PM
code p-1693 gino23 5.9L Cummins (2003-2007.5) 1 03-15-2007 10:26 PM
