HX35/40 Hybrid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01_24valve, this thread has received 15 replies and been viewed 10829 times.
post #1 of 16 (permalink) Old 04-10-2009, 02:59 AM Thread Starter
01_24valve's Avatar
HX35/40 Hybrid
Just ordered an 60mm compressor for my stock turbo. I know that this is nothing new but i haven't found anyone on here that has posted pictures and talked about the machining that has to be done. So that is my intention, i will have dyno sheets and also cost, difficulty, and pictures. The first dyno pull will be 4/25/09. Rumor has it that a Hx35/40 adds around 50 hp, but i plan on testing it. If anyone has done this before and knows of problems i may encounter i would really like to have the warning.
01_24valve is offline
post #2 of 16 (permalink) Old 04-10-2009, 03:13 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
*Sigh* 4 turbos laying around our shop. Tisk tisk.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 16 (permalink) Old 04-10-2009, 03:31 AM Thread Starter
01_24valve's Avatar
lol i know as if we don't have enough. wait what am i saying there is never to many turbos.
post #4 of 16 (permalink) Old 04-10-2009, 04:27 AM
Let me know about that machining, I'm curious as well. I was just reading about those as well, and it said that 98.5 and newer Autos needed machining. And I'm curious about the turbos off of sticks, because the one on my truck now actually came off an 02 6spd, because I couldn't get my exhaust housing freed up to clock it for the twins. Anyways, keep us posted. It should allow for a bit more air, and they seem pretty reasonably priced.
post #5 of 16 (permalink) Old 04-10-2009, 04:33 AM Thread Starter
01_24valve's Avatar
i believe the spec is to machine the baring mount on the compressor side to hold a .040 bigger baring. I will have more info when the parts get here. Price isn't to bad high tech turbo kit i bought was 375 + shipping. stock the compressor is 54mm and with the hybrid it will be a 60mm compressor so it adds 6mm. I expect the spool speed to be a little slow because of the extra weight being added to the rotating assembly and also because it will have the Resistance of the extra air flow. But all that should be cured with the 200hp sticks and the dragon fire extreme i have planed for it in the next 4 months!
post #6 of 16 (permalink) Old 04-10-2009, 06:36 PM
I don't think spool up will be an issue with 200hp sticks. You will be running really hot again though.
post #7 of 16 (permalink) Old 04-11-2009, 01:03 AM Thread Starter
01_24valve's Avatar
very ture but oh well just means i need twins!! lol But that will be a while yet.
post #8 of 16 (permalink) Old 04-11-2009, 11:07 AM
I've ran one for years. If price says anything I gave 185 dollars for my wheel and housing when I bought it. Makes a decent turbo, I've seen way to much boost out of mine several times. Getting the shaft back threw the snap seal was the hardest part of the reassembly. I would drill the divider out on the exhaust side while it was apart just to help it flow a little better.
01,qcsb,fwd,he351-3b twins,125 horse injectors,adrenaline pulse,5 inch ex. to 5 in. stacks,on board air,5 disk convertor
02 qcsb,fwd,35-40,edge juice,mach 2.5 injectors,4 inch exhaust,billet trans, 4 disk convertor
gwhammy is offline
post #9 of 16 (permalink) Old 04-11-2009, 05:01 PM Thread Starter
01_24valve's Avatar
Thanks for the heads up. And yes i was planing to take out the divider to allow all six cylinders to have the ability to reach the waste gate, but flow is another good reason to.
post #10 of 16 (permalink) Old 04-11-2009, 06:12 PM
Hot Rod Farm Boy
I turned 21
Port the wastegate a bit while you're in there.
Logan
S480 under hx35? SSpeeDEMONSS 5.9L Cummins 12 Valve (1994-1998.5) 4 03-10-2009 02:46 PM
HX35 & HX 40 questions. GetPlowed12valv 5.9L Cummins 12 Valve (1994-1998.5) 18 02-04-2009 11:42 PM
Want HX35 off a dodge Onebadtruck Whats Been Sold 0 04-25-2008 04:53 PM
HX35 cheap Dazedandconfused Whats Been Sold 0 05-22-2007 02:02 AM
HX35 hybrid, BHT3B 3rd gen Twins Rick D Whats Been Sold 2 03-11-2006 09:12 PM
