error codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by martin62, this thread has received 4 replies and been viewed 1402 times.
post #1 of 5 (permalink) Old 04-10-2009, 08:01 AM Thread Starter
error codes
2001 2500 6 speed Truck acts like it running out of fuel let off the pedal for a few seconds then it well take off again then dies .Go's then dies, go's then die ,on an on . got over 15 psi fuel pressure . changed the fuel filter. errors code go as follow p 0460, p 1693 ,(fuel gauge don't work) then the next set of code are ,p 1689 , p 0216, p 1693.
martin62 is offline
post #2 of 5 (permalink) Old 04-10-2009, 02:28 PM
cowboytw13's Avatar
P0216 Fuel Injection Pump Timing Failure (dead vp-44)
P0460 like you said fuel gauge
P1693 Companion codes
P1689 No Communication between ECM and Injection Pump Module.
You could have a short between the ECM and injection pump, or just something unplugged. I'd take a look and see if you can find anything that's unplugged. Hopefully that's what's throwing the p0216 code.
cowboytw13 is offline
post #3 of 5 (permalink) Old 04-10-2009, 03:51 PM
one thing that needs done to the vp is adding the ground to the system as they stock ground sucks. thats what causes a lot of the 1689's
01quadcab is offline
post #4 of 5 (permalink) Old 04-10-2009, 03:56 PM
2nd Gen Guru
Mopar1973Man's Avatar
Also check the Fuel Pump relay it controls the power to the VP44...
Mopar1973Man is offline
post #5 of 5 (permalink) Old 04-11-2009, 01:02 AM
what is a good way to ground a vp 44 pump
muffdaddysram is offline
Error Codes Dump and Code Listing Mopar1973Man General Dodge Discussion 7 01-03-2010 02:13 AM
Error Codes and Stalling GreasyRides 6.5L Diesel Engine 9 07-19-2007 01:01 PM
Error Codes?? yackelb 5.9L Cummins (1998.5-2002) 4 12-01-2006 04:26 PM
