Low Fuel Pressure during acceleration - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MT45 WALKER, this thread has received 13 replies and been viewed 3217 times.
post #1 of 14 (permalink) Old 04-11-2009, 04:17 AM Thread Starter
Hi,
Just installed a Low Fuel Pressure gauge via a Blue Chip FMS box. Diagnostic checks - OK, but experiencing LOW FUEL PRESSURE during acceleration.
What gives? I would appreciate any advice. It is a weekend so cannot call Blue Chip till Monday.
Anyone else have the same experience? Please help. Thanks!
MT45 WALKER is offline
post #2 of 14 (permalink) Old 04-11-2009, 04:59 AM
do you have anything other than the stock lift pump? If not it's time for a upgrade fass airdog raptor something that will supply enough fuel to keep up with the box.
01quadcab is offline
post #3 of 14 (permalink) Old 04-11-2009, 07:32 AM Thread Starter
Roger that. I will give it a shot. Thanks for your input!
post #4 of 14 (permalink) Old 04-11-2009, 03:22 PM
the stock can barely keep up with a stock truck so it's just needing some fuel.
post #5 of 14 (permalink) Old 04-12-2009, 11:53 PM
2nd Gen Guru
Mopar1973Man's Avatar
Your best to get a actual gauge that you can see... Because you want to keep the fuel pressure above 10 PSI...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
MT45 WALKER (04-16-2009)
post #6 of 14 (permalink) Old 04-15-2009, 02:22 PM
bmoeller's Avatar
At least you have pressure at all. I finally got the Juice hooked up last night, and I have 0.
"Obama = Hoax and Chains"
bmoeller is offline
post #7 of 14 (permalink) Old 04-15-2009, 02:57 PM
2nd Gen Guru
That's why I suggest ot everyone to upgrade the fuel system before you EVEN think of adding a fueling box... Even before that add a set of gauges...
I think the bad part is everyone runs around with stock system wait for the Edge Juice and the OPPS I got nothing... I hate to say it a fuel pressure gauge is extremely cheap... $40 buck to install compared to a Edge product of $500-$600 bucks...
post #8 of 14 (permalink) Old 04-17-2009, 05:32 PM
haz-mat19's Avatar
Yep, when I got my f/p gauge installed prior to any extra fueling I found 6 at idol and 0 at mild acceleration. Luck for me I was still under warranty. Since the FASS never goes below 15. Get the fuel system fixed before you hook up that box or you will need a new I/P.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #9 of 14 (permalink) Old 04-19-2009, 08:11 PM
tbroadus_41's Avatar
I've got a Fass 150 gph pump and i can still get it down to 5 psi under accel! What Give's
tbroadus_41 is offline
post #10 of 14 (permalink) Old 04-19-2009, 10:41 PM
cowboytw13's Avatar
Dirty fuel filter, clogged fuel line, or could be sucking air. check you filters and make sure they're tight. Also, check all you fittings. If it is sucking air, the pump should seem a little louder and make a kind of gurgling noise.
cowboytw13 is offline
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
$100 Off DJ's FUEL+ - Fuel Pressure Intensifier MOMBENZ Supporting Vendors Forum 3 12-13-2006 01:49 AM
anyone doing fuel pressure or oil pressure skinz0021 General Dodge Discussion 7 08-19-2006 02:42 PM
