hit the track again - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01quadcab, this thread has received 31 replies and been viewed 2159 times.
post #1 of 32 (permalink) Old 04-13-2009, 04:56 AM Thread Starter
hit the track again
well last night ran the truck again to the tune of 12.92 at 103.12.
01quadcab is offline
post #2 of 32 (permalink) Old 04-13-2009, 05:22 AM
Carolina Boy
Das Bar 2k4's Avatar
nice run
Greg aka Cumminsproud
Go Clemson Tigers Football
96 Ram 3500 Slt Ext Cab 12v cummins nv4500 afc housing and plate full forward with 4in exhaust and k&n drop in and smoke screw turned in a few turns it wants to be a 2.6 truck
94 Ram 2500 Slt Reg Cab 12v cummins auto: custom grind fuel plate, afc housing ff, afe stage 2 bhaf, mbrp 4in str8 pipe exhaust, 3k gsk, isspro gauges trans, egt, and boost, 20in Moto Metal punishers on 33's -let the smoke start rollin
new truck 96 p pump 24v
floor it diesel performance and raw diesel performance all the way
Bracken Pullin Team 2008-2010 MSTPA Points Champions
SINGLES CLUB # 210 former
DUALLY CLUB # 92 Wide Body Status
Das Bar 2k4 is offline
post #3 of 32 (permalink) Old 04-13-2009, 05:46 AM Thread Starter
thanks. I was 14.23 2 weeks prior but getting rid of the torque management really helped. Going to try more boost on launch next time.
post #4 of 32 (permalink) Old 04-13-2009, 06:05 AM
Carolina Boy
nice numbers indeed, i need to get to work on my truck but i've been lazy but it's about time to go through the tranny and get it right. so can make some more power.
post #5 of 32 (permalink) Old 04-13-2009, 09:35 PM
Thats pretty nice man.
Are you running the BD unit, or just interupt the CCD wire?
Also, how much boost did you launch at?
What kind of boost are you seeing on your runs as well?
Are you running a lock up switch?
post #6 of 32 (permalink) Old 04-14-2009, 04:20 AM Thread Starter
I ran the bd unit it works nicely. Just no tach or speedo. I launch at 20psi and I am not sure what boost I am seeing on my runs as the edge is off from a manual gauge so I need to mount the manual one I picked up in a better spot. I did hit 49 getting the freeway the other day while testing out the bd and the converter lock up switch. I added both of them before the drags and picked up 1.3 seconds. Need more fuel
post #7 of 32 (permalink) Old 04-14-2009, 04:45 PM
what kind of trans/ mods do u have????
Josh
01 2500 dodge 24 valve 200k miles, striaght pipe exhaust, bully dog j-hook,home made cold air intake,Full Georend tranny,billet input,billet output,lam flex plate, TQ lock-up switch, Holley Blue pump, RV275's, BD top speed elimintator w/RAD Hot Edge juice w/Attitude
:smoke
masonjo is offline
post #8 of 32 (permalink) Old 04-14-2009, 05:39 PM
What is the weight on your truck? Is it a long bed or short bed?
post #9 of 32 (permalink) Old 04-14-2009, 05:56 PM Thread Starter
billet input shaft, tcs billet trip disc converter, hts valvebody.
weight without me in it and 1/4 tank of fuel was 6740 add me and another 1/4 tank of fuel and it's over 7000. it's a short bed.
post #10 of 32 (permalink) Old 04-14-2009, 06:54 PM
Carolina Boy
nice i was wondering how well the lock switch worked
A track paa vid. imported_BillM2004 5.9L Cummins (2003-2007.5) 6 10-31-2007 02:56 AM
Went to the track!!! MikeRJ13 Drag Racing 0 07-06-2007 01:47 AM
Went to the track.... imported_DieselKid 2003-2007 6.0L Power Stroke 56 02-24-2007 04:18 AM
Went to the track!!!!!!! BFD99 Drag Racing 10 11-13-2006 02:25 AM
Off track here!! pirogue General Ford Truck and Excursion 13 01-04-2006 12:24 AM
