mpg injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins-dodge, this thread has received 13 replies and been viewed 5329 times.
post #1 of 14 (permalink) Old 04-19-2009, 10:41 PM Thread Starter
mpg injectors
what are the biggest horsepower injectors that i can run and still get good mpg
01 258000 miles 5spd reg cab cummins hot unlock edge juice, 4" down pipe, 5" stacks, afe, cooler tubz, 33x12.50x16.5 tires, ranch hand bumbers
01 255000 miles 5spd quad cab cummins hot unlock edge juice, 4" down pipe, 6" stacks, afe, cooler tubz, duel electric fans, 4" lift, 36x12.50x16.5 tires, ranch hand bumbers
cummins-dodge is offline
post #2 of 14 (permalink) Old 04-19-2009, 11:01 PM
Official TDG Doctor
hccumminssmoke's Avatar
I'd say you could get by with 125s maybe 150s and still get good mpgs...but it all depends on how much love you give the skinny pedel...If you go that big then you will want to get a turbo...w/o a turbo i'd say some 75 horse ones would not be too smokey...
Nate
hccumminssmoke is offline
post #3 of 14 (permalink) Old 04-19-2009, 11:23 PM Thread Starter
i would like to get more smoke but still have good mpg's i found all the way up to 300 hp injector nozzles on e-bay look under cummins injectors i am looking to go with twins maybe
post #4 of 14 (permalink) Old 04-20-2009, 12:13 AM
Official TDG Doctor
never heard of 300hp nozzs, and 200-240 is gonna be all you want on the street and your mpgs are gonna suck, you deffinitly gonna have to get a heafty LP for that too...if you think you'll get better then 16mpgs w/ that high of a stick I've got some ocean front property in 'Zona I'll sell ya too...
Nate
post #5 of 14 (permalink) Old 04-20-2009, 03:36 AM
I have a set of bosh 275's and they get good mpgs work real well with the stock charger and can smoke very well when you want them to. I went bigger turbo and bigger injectors so I am selling these only have 1k on them since pop tested and rebuilt.
01quadcab is offline
post #6 of 14 (permalink) Old 04-20-2009, 05:23 AM
Nate
I'm throwing some 200's in mine, and I bet I can still pull decent numbers with them. Its all in how you drive. I can still pull 21.5 with the 110's.
post #7 of 14 (permalink) Old 04-20-2009, 05:42 AM
Of Course
Stock pintle lift for mileage, hone size 0.010" and under.
That Guy is offline
post #8 of 14 (permalink) Old 04-21-2009, 11:30 PM
I now drive a Duramax...
LoL...
2007 Chevrolet 3500 SRW CrewCab Longbed, PPE Modded AirBox, Edge Evo Race level 4.
***SOLD***2001 Dodge 2500 CTD Quadcab Longbed SRW, Straightpiped, BHAF, no silencer ring.
They call it PMS because Mad Cow Disease was taken...
CumminsTorq is offline
post #9 of 14 (permalink) Old 04-22-2009, 02:58 AM
JLWelding's Avatar
It has a little to do with how much you weigh. I installed 75hp and fuel mileage went out the tailpipe. Went from 16 to 14. Truck weight 8900lbs.On a empty day. Stock weight 6700lbs.
JLWelding is offline
post #10 of 14 (permalink) Old 04-22-2009, 04:31 PM
Singles Club #2
smokndiesel7588's Avatar
I'm running dynomite diesel 110hp injectors, and i've seen 23.x mpg cruisin around 50-55mph. I can also get 14 mpg with them...all depends on how much throttle i decide to use.
Greg
smokndiesel7588 is offline
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
Injectors Andy 1994-2003 7.3L Power Stroke 2 03-17-2007 11:30 PM
injectors? des6120 1994-2003 7.3L Power Stroke 9 02-17-2007 05:10 PM
6.0 injectors Tim @ P.I.S. Whats Been Sold 0 02-17-2007 02:40 AM
Injectors Fast_Ashley 1994-2003 7.3L Power Stroke 45 02-16-2007 02:18 PM
