A few VP44 questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by richarr9, this thread has received 7 replies and been viewed 1731 times.
post #1 of 8 (permalink) Old 04-21-2009, 08:51 PM Thread Starter
richarr9's Avatar
Well my brothers truck wont start, ran for 2 days after I put an airdog on it, it has a few codes, several are crank sensor related, but one of them is a P0370, I pull up the diag table for that code and all it says is if that code is present the IP is toast. So I am going to double check a few things but I am pretty sure it needs a new pump. Right now he has a quadzilla adreniline and exhaust and air filter. We were maybe thinking of a hot rod VP44, probably one from schied, what are peoples opinion on that, also would that be to much fuel with the adreniline and hot rod pump, on stock injectors and turbo.
96 Chevy K3500 6.5 diesel with 230k miles
4" lift 4" exhaust and PMD heatsink
And a DT466 going into a 2.5 ton 6x6 army truck
put it in 3rd. gear & nailed it & it took off like a missile for about 50 ft. & then the turbo exploded kinda like a missile!!!
richarr9 is offline
post #2 of 8 (permalink) Old 04-21-2009, 10:10 PM
Official TDG Doctor
hccumminssmoke's Avatar
what was his fuel pressure like w/ the AirDog? What are his goals for the truck? You can get 600hp out of a good SO VP and save oh about 9-11 hundo then buying a HRVP...I personally wouldnt go with a HR, but thats just me...
Nate
hccumminssmoke is offline
post #3 of 8 (permalink) Old 04-22-2009, 03:58 PM
What are sparkplugs
ICEMAN3005's Avatar
If you go hotrod vp then you need at least 150 hp over stock inj. and a turbo upgrade I recommend twins. and at least a 150 gph pump, I would go 200, my 150 couldn't keep up sometimes. Will also need a billet trans with aftermarket flex plate torque converter and valve body if its an auto, or a better clutch plus billet input on a manual.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #4 of 8 (permalink) Old 04-22-2009, 06:10 PM
2nd Gen Guru
Mopar1973Man's Avatar
Stick with the SO pump and mild injectors with a good enhancement box stacked with a programmer and you'll get some killer HP/TQ out of it...
But that my personal opinion...
Mopar1973Man is offline
post #5 of 8 (permalink) Old 04-22-2009, 10:16 PM
What are sparkplugs
ICEMAN3005's Avatar
I agree with moparman only do hotrod pump if you have lots of money otherwise stick with stock pump, use a programmer/box/chip.
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #6 of 8 (permalink) Old 04-23-2009, 12:48 AM
Of Course
Why would you replace the injection pump when you are getting CPS codes? Is the truck a '98-00?
That Guy is offline
post #7 of 8 (permalink) Old 04-23-2009, 02:25 AM Thread Starter
richarr9's Avatar
The crank pos sensor codes didnt lead anywhere, I will double check everything before I do a pump, but the P0370 code was pretty well defined, if its there the pump is shot, and yes the truck is a 2000, with a manual.
richarr9 is offline
post #8 of 8 (permalink) Old 04-24-2009, 08:14 PM
Of Course
I've seen a broken wire going to the CPS cause a no start condition. It would be much cheaper to eliminate the first. If code P0370 is present, the tone ring on the VP44 is losing signal, which is quite rare.
That Guy is offline
Hot VP44 or Blue Chip's VP44 Mad Dog Cycles 24 Valve Performance 12 05-03-2009 01:38 AM
vp44 dodgeman00 Whats Been Sold 3 03-11-2009 01:41 PM
vp44 questions? 01_24valve 5.9L Cummins (1998.5-2002) 13 03-05-2009 06:54 PM
Hp With Vp44 DSR 5.9L Cummins (1998.5-2002) 9 04-30-2008 06:44 AM
Vp44 iwannagofast Whats Been Sold 5 02-22-2008 03:20 AM
