auto to standard? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummings24v, this thread has received 23 replies and been viewed 1720 times.
post #1 of 24 (permalink) Old 04-24-2009, 03:56 AM Thread Starter
Cummings24v's Avatar
auto to standard?
Is possible to swap an auto trans to a manual in a 99 2500 quad cab, short box, 4x4? Looking into auto trans upgrades... lots of $$!!
Cummings24v is offline
post #2 of 24 (permalink) Old 04-24-2009, 03:59 AM
bmoeller's Avatar
Unless you have a cheap donor truck with all of the needed parts, the built auto might come out ahead.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 24 (permalink) Old 04-24-2009, 04:02 AM Thread Starter
I can get the manual cheep.... and im good at torching holes in floor boards!!
post #4 of 24 (permalink) Old 04-24-2009, 04:38 AM
Take your time if you are going to do the swap and do it right, other wise your truck will loose value and not work correctly. My opinon I would build the auto.
later is offline
post #5 of 24 (permalink) Old 04-24-2009, 07:26 PM
What are sparkplugs
ICEMAN3005's Avatar
a good built auto will cost $6000-$8000 E.G. billet components, valve body, billet TC etc.
a manual swap will cost about $3000-4000, I had priced everything, new crossmember, drive shafts, flywheel, clutch pedal/brake assembly, billet input shaft, southbend clutch, etc, and a used 5 spd. before I sold truck my truck, I wanted the manual.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #6 of 24 (permalink) Old 04-24-2009, 07:54 PM
you can get a good built auto for right about the same as doing the swap. Just gotta shop around
01quadcab is offline
post #7 of 24 (permalink) Old 04-24-2009, 10:36 PM
Ghost
Phily's Avatar
You're gonna lose acceleration, even length legs and the worlds best cup holders.
For all the money you going to dump into this, you could do wonders with your auto. I've owned all, stock Auto, built Auto and 6 speed manual. I know you hate autos just like I did when I had a stock auto, but after I built my automatic I knew autos were the way to go. The only reason I bought a 6spd was for the High Outputs added fuel MPG.
Phily is offline
post #8 of 24 (permalink) Old 04-25-2009, 02:37 PM
2nd Gen Guru
Mopar1973Man's Avatar
Thats the tough part figuring out what you plan to do with the truck. If you hauling trailers and such the manuals do great for that. But if you plan on racing the Auto is the best place to be. Unless you can row gears fast...
Mopar1973Man is offline
post #9 of 24 (permalink) Old 04-25-2009, 04:52 PM
Real fast for that matter.
Carbur8tr is offline
post #10 of 24 (permalink) Old 04-25-2009, 10:26 PM
99 cummins
customdeluxe78's Avatar
i'm a big fan of the stick. if i was going to convert one, i would just but a donor truck! by the time you buy everything separate, you could buy a truck and have everything you need. i've converted a few older chevy's from auto's to 4-speeds and was well worth it.
a built auto would be nice but not as nice as jamming gears!
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
Auto vs Standard Pourinthecoal 5.9L Cummins (2003-2007.5) 12 08-17-2009 12:42 PM
running a auto chip in a standard DUMPIN99 1994-2003 7.3L Chips & Tuners Forum 7 03-06-2008 12:45 PM
91 non-ic 4x4 standard cab/auto tranny Rusty Workhorse 5.9L Cummins (Pre 1994) 5 09-11-2007 04:22 AM
LSD standard? Snow 5.9L Cummins 12 Valve (1994-1998.5) 10 02-27-2007 05:15 PM
automatic vs standard joetib81 5.9L Cummins (2003-2007.5) 10 01-03-2007 05:40 AM
