Trans lock up - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by King, this thread has received 10 replies and been viewed 999 times.
post #1 of 11 (permalink) Old 04-26-2009, 06:38 PM Thread Starter
Trans lock up
I recently purchased a 2000 dodge 3500 with a cummins and a auto trans. Has a bigger turbo and 5 inch exhast, with 3.55 gears. Cant seem to keep it locked up when towing about a 9000lbs load in a enclosed trailer.
King is offline
post #2 of 11 (permalink) Old 04-26-2009, 07:39 PM
What are sparkplugs
ICEMAN3005's Avatar
Just install a lock up switch!!!!!
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #3 of 11 (permalink) Old 04-26-2009, 07:43 PM
Ghost
Phily's Avatar
Stock tc? Probably slipping like me drunk on ice. I'd still put a switch on it to make sure it's nothing electronic. If it's locking up unloaded though that makes me believe it's the t/c itself though.
Disclaimer: Upgrading the t/c on these will cause you to fall in love with your truck.
Phily is offline
post #4 of 11 (permalink) Old 04-27-2009, 02:12 AM Thread Starter
What kind of switch? Where can obtain one? How do they install? I understand how they work, but I was browsing around today and couldnt find anything for this application
King is offline
post #5 of 11 (permalink) Old 04-27-2009, 02:16 AM
Ghost
Phily's Avatar
You can most likely do it right now. Jump your transmission relay, t into your orange w/ black tracer wire out of the middle harness on the PCM and run it to a ground and control it with a switch.
(I think I said that right, I'm alittle rusty)
Phily is offline
The Following User Says Thank You to Phily For this addition to TDG:
King (04-27-2009)
post #6 of 11 (permalink) Old 04-27-2009, 02:22 AM
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
01quadcab is offline
The Following User Says Thank You to 01quadcab For this addition to TDG:
King (04-27-2009)
post #7 of 11 (permalink) Old 04-27-2009, 02:44 AM Thread Starter
Is the edge juice attitude the way to go for this truck?
King is offline
post #8 of 11 (permalink) Old 04-27-2009, 04:41 AM
I like it, or the edge comp and gauges but that makes the juice cheaper
post #9 of 11 (permalink) Old 04-27-2009, 01:12 PM
What are sparkplugs
ICEMAN3005's Avatar
use a two prong switch one side ground other lead wire from TC wire (should be solid orange or orange with white strip) coming of PCM on fire wall, cut and splice lead wire into TC wire. will need a .5 OHM resister on ground side
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #10 of 11 (permalink) Old 04-27-2009, 04:55 PM
Official TDG Doctor
hccumminssmoke's Avatar
I wouldnt put a lock up switch on a Stock Converter, many die that way...just saying....
Nate
hccumminssmoke is offline
TQ lock up for an 06 dangerous196 5.9L Cummins (2003-2007.5) 3 05-01-2008 11:37 AM
is good idea 2 lock auto trans heathww 24 Valve Performance 5 01-29-2008 05:17 AM
lock up blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 7 01-19-2008 10:42 PM
T/C lock up mod SMOKIN 1994-2003 7.3L Power Stroke 9 09-01-2007 08:19 AM
7.3 Trans lock up switch Seventy468 1994-2003 7.3L Power Stroke 1 07-06-2006 05:04 PM
