Acronyms - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Phily, this thread has received 16 replies and been viewed 10350 times.
post #1 of 17 (permalink) Old 04-26-2009, 08:10 PM Thread Starter
Ghost
Phily's Avatar
Acronyms
I was thinking, we deal with tons of acronyms/abbreviations/etc.
VP44: Injection pump found on 98.5-02 Dodge Cummins
T/C: Torque Converter
TCC: Torque Converter Clutch
V/B: Valve Body
ISB: Interact System "B"
QSB: Quantum System "B"
HO: High Output engine
SO: Standard Output engine
ETH: HO engine
ETC: SO engine
47RE: Automatic transmission found behind the Dodge Cummins (& v10) 96-03? 04?
47RH: Automatic Transmission found behind the Dodge Cummins (& v10) 94-95
NV4500: 5 Speed Manual found behind the Dodge Cummins (& v10) 94-03?
NV5600: 6 Speed Manual found behind the Dodge Cummins 1999.5-2004
DEE: NV5600
CAD: Center Axle Disconnect
ATF: Automatic Transmission Fluid (or Alcohol Tobacco & Firearms)
MPG: Miles Per Gallon
CTD: Cummins Turbo Diesel
BHAF: Big Honkin' Air Filter
KDP: Killer Dowel Pin
DRW: Dual Real Wheels
SRW: Single Real Wheels
FASS: Most common replacement fuel pump on Dodge Cummins
L O L : Laugh Out Loud or Legs of Lamb
OBD: On Board Diagnostics
DTC: Diagnostic Trouble Code
ECM: Engine Control Module
PCM: Powertrain Control Module
APPS: Acceleration Pedal Position Sensor
MIL: Malfunction Indicator Lamp
RPM: Engine Rotations Per Minute
That's all I can think of right now, help me add more to this list,be a good thing to copy and paste for newbs.
Phily is offline
post #2 of 17 (permalink) Old 04-27-2009, 03:41 AM
CEL: check engine light.
CPS: crank position sensor
Thats a good start phily and I'm sure it will be helpful to some people.
post #3 of 17 (permalink) Old 04-27-2009, 04:34 PM
I now drive a Duramax...
D60: Front axle found on 2500 Dodge's
D70: Rear axle found on 2500 Dodge's
D80: Rear axle found on 3500 Dodge's
2007 Chevrolet 3500 SRW CrewCab Longbed, PPE Modded AirBox, Edge Evo Race level 4.
***SOLD***2001 Dodge 2500 CTD Quadcab Longbed SRW, Straightpiped, BHAF, no silencer ring.
They call it PMS because Mad Cow Disease was taken...
CumminsTorq is offline
post #4 of 17 (permalink) Old 04-27-2009, 04:38 PM
2nd Gen Guru
Mopar1973Man's Avatar
IAT - Intake Air Temperature
MAP - Manifold Air Pressure
ECT - Engine Coolant Temperature
VP44 - 24V 2nd Injection pump (Hold shift key and type VP$$ - Very Pricey pump!)
Mopar1973Man is offline
post #5 of 17 (permalink) Old 04-27-2009, 04:50 PM
Think we've left out an important one.
EGT: Exhaust Gas Temperature.
DP: Is either Down pipe, or Drive pressure, so look at context.
IC: Intercooler
post #6 of 17 (permalink) Old 04-27-2009, 04:53 PM
Official TDG Doctor
hccumminssmoke's Avatar
TDTC- Triple Disc Torque Converter
DD- Dual Disc (Clutch)
I use those quite a bit myself...
Nate
hccumminssmoke is offline
post #7 of 17 (permalink) Old 04-27-2009, 05:35 PM Thread Starter
Ghost
Phily's Avatar
Nate
What's your abbreviation for the ATS TC then?
Phily is offline
post #8 of 17 (permalink) Old 04-28-2009, 01:56 PM
2nd Gen Guru
Come on guys let hold to the thread topic and keep out of personal comments please...
post #9 of 17 (permalink) Old 04-28-2009, 03:06 PM
Official TDG Doctor
BHAF- Big Honkin Air Filter
OD- Over Drive
OEM- Original Equipment Manufacturer
WOT- Wide Open Throttle
Im at the bottom of the barrell...
Nate
post #10 of 17 (permalink) Old 04-29-2009, 01:39 AM
dodgefarmer2's Avatar
sorry i crossed the line.
LSD-(not the drug) low sulfur diesel
ULSD-ultra low sulfur diesel
S.A.E.- society of automotive engineers
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
NOOBE acronyms help or FAQ ?? two-rocks 1994-2003 7.3L Power Stroke 6 07-24-2007 02:26 AM
