01 dodge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by muffdaddysram, this thread has received 11 replies and been viewed 1213 times.
post #1 of 12 (permalink) Old 04-26-2009, 10:57 PM Thread Starter
01 dodge
i got an 2001 dodge ram 3500 cummins, i have went threw 12 vp 44 injection pump.the truck is stock.i got an raptor 150 [email protected] 15 psi,new app sen.just put new pump on and made it 18.7 miles.cummins compute onlys shows the codes for bad pump.we even in stalled new ecm on the engine,and it still burn them up.does any body got any ideas.if do email or call me asap.513 941 7566.no body as never saw this before.,all yea codes on the dash say p 1693 then it says p done.i know for a fact because i have ben f ing with dis for 3 weeks now. the injections pumps are burning the plunger and computer up in yhem.......help me please!!!!!!!!!!!!!!
muffdaddysram is offline
post #2 of 12 (permalink) Old 04-26-2009, 11:47 PM
JLWelding's Avatar
Man I feel for ya, you been threw some real crap. I dont have a clue, maybe Moparman can chime in. I would have set it on fire by now.
JLWelding is offline
post #3 of 12 (permalink) Old 04-27-2009, 02:18 AM
ppump conversion....
01quadcab is offline
post #4 of 12 (permalink) Old 04-27-2009, 01:10 PM
What are sparkplugs
ICEMAN3005's Avatar
after second vp died I would have gone to P-pump
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #5 of 12 (permalink) Old 04-27-2009, 04:45 PM
2nd Gen Guru
Mopar1973Man's Avatar
1. ECM is having problems... You should see 2 P-Dones and P-PCU and P-ECU. Here is the order it should display...
Here is a video of this...
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
Here is a thread I started... You can't have just a P1693 code by itself...
https://www.thedieselgarage.com/forum...ad.php?t=74996
So since you getting just a P1693 that means the ECM is holding the other codes and is NOT communicating with the PCM to display the error code. You going to have to stop in a Dodge dealer to get the codes from the ECM.
Mopar1973Man is offline
post #6 of 12 (permalink) Old 04-27-2009, 09:24 PM Thread Starter
mopar man
i get what you are saying but it anit happen on my truck,we even in stalled a new ecm on the side of the block and it is still fuct up.it say 1693 p done
post #7 of 12 (permalink) Old 04-27-2009, 09:30 PM Thread Starter
p pump
what is a p pump and what does it do.any picks and how much
post #8 of 12 (permalink) Old 04-27-2009, 11:58 PM
JLWelding's Avatar
A PPump is what the 12 valves have for injection pump. In fact there is a new one on the Dodge parts site. I now this, if mine is on the way out thats what I am going with. I cant get any codes to come up. When your vp is going out does your truck lope at times at red lights? Does it have a litte rev up to it when you let off. Does it have a eratic idle to it? These are the things my truck is doing.
post #9 of 12 (permalink) Old 04-28-2009, 02:08 PM
2nd Gen Guru
JL... Your still after that crazy idea huh?
Well let the guy know about how much MORE its going to cost and the amount of work you got ahead of him (yourself included).
* Need to change gear case (This includes pulling the cam)
* Need to change all throttle linkage
* Buy the p-pump
* Buy the custom High pressure tubing
* Change lift pumps (VP44 requires less pressure than a P-pump)
* Deal with the electronics (ECM/PCM)
* And possibly change injectors (or calibrate for the change in pop pressure).
* Also buy the timing kit so you can time your new P-pump. (Spendy!)
I've never done it myself but in not as easy or as cheap as changing a VP44... I got to admit the p-pump once its install is a mean pump and will last for ever...
post #10 of 12 (permalink) Old 04-28-2009, 03:53 PM
the cost of all parts is like 2500 and then some labor. But the price of 2 vps pays for it. And the lift pump just needs a spring upgrade and they work fine. if they have a fass at least.
92 dodge will not run!!!!!!!!! 99cummins3500 5.9L Cummins (Pre 1994) 6 09-12-2007 10:28 PM
stock chrome dodge wheels fit ford chevy dodge strokedout_07 Whats Been Sold 2 03-04-2007 04:11 AM
set of chrome dodge wheels for ford chevy dodge strokedout_07 Whats Been Sold 0 03-03-2007 07:39 PM
new dodge BLACKPHANTOM General Dodge Discussion 3 02-12-2007 11:49 PM
98 dodge 12 or 24? JeepinHackSaw 5.9L Cummins 12 Valve (1994-1998.5) 26 12-21-2006 06:24 PM
