Plug or Boost Elbow - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rwhite, this thread has received 13 replies and been viewed 4193 times.
post #1 of 14 (permalink) Old 04-29-2009, 03:49 PM Thread Starter
Plug or Boost Elbow
I was going to just plug rather than use a boost elbow on the turbo. Much cheaper. Any downside?
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #2 of 14 (permalink) Old 04-29-2009, 04:13 PM
Singles Club #2
smokndiesel7588's Avatar
Thats all the mechanic did for my buds truck..he didnt have any problems with it.
Greg
smokndiesel7588 is offline
post #3 of 14 (permalink) Old 04-29-2009, 05:00 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
what do you mean plug it like plugin in a strew and stopin the air gettin in? need more info
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #4 of 14 (permalink) Old 04-29-2009, 05:17 PM
Just plugging the line will work. However, it will result in higher boost pressures and push the turbo out of its map. Another common thing to have happen when you plug the line is for the wastegate itself to freeze shut due to a lack of use. Unfreezing them isn't that hard though. The air you are going to be getting above about 32psi starts losing its oxygen density and does you little good, and causes your EGT's to rise. I guess all I'm saying is that the extra boost from the plug isn't gaining you anything. Its not likely that it will be hurting anything either, but if you're turning 2500 RPM and have 40psi boost, you are definitely pushing the limits of your turbo and may likely see shaft failure.
post #5 of 14 (permalink) Old 04-29-2009, 05:56 PM
Official TDG Doctor
hccumminssmoke's Avatar
i've got my elbow off my junker HX...i'll cut you a deal on it...
Nate
hccumminssmoke is offline
post #6 of 14 (permalink) Old 04-29-2009, 07:26 PM
I would run the eblow and not plug it.
01quadcab is offline
post #7 of 14 (permalink) Old 04-29-2009, 09:14 PM Thread Starter
which of the two is the "safer" alternative - I'm just looking for a little more boost - max right now is 19/20 psi
rwhite is offline
post #8 of 14 (permalink) Old 04-29-2009, 09:31 PM
the elbow is the safer one.
post #9 of 14 (permalink) Old 04-30-2009, 02:23 AM
JLWelding's Avatar
Get a adjustable elbow. That way your waste gate is still working and no over boost.
JLWelding is offline
post #10 of 14 (permalink) Old 04-30-2009, 05:02 PM
Nate
i asked round here and seem anybody needed one and no one wants it but i finally got mine and dads got his when he got his edge juice
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
Boost elbow and 3k gsk ?'s moparcummin 12 Valve Performance 3 07-08-2009 11:11 PM
Boost Elbow? smokercummins74 5.9L Cummins 12 Valve (1994-1998.5) 3 01-11-2009 07:07 PM
Boost elbow kc04 5.9L Cummins (2003-2007.5) 4 01-13-2008 11:26 PM
boost elbow wistlnwoodchuck 5.9L Cummins 12 Valve (1994-1998.5) 9 07-22-2007 04:02 AM
Boost elbow...? swmnkdinthervr Whats Been Sold 3 03-12-2006 08:20 PM
