tuner help new cummins owner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by slickricks7.3, this thread has received 26 replies and been viewed 1828 times.
post #1 of 27 (permalink) Old 04-29-2009, 11:19 PM Thread Starter
Just strokin an smokin
Send a message via AIM to slickricks7.3
I just recently bought 98 cummins 5.9 24 valve with a 5 speed stick
I have had a duramax an a power stroke but this is the frist cummins
Im looking for any advice i can. JUst looking to get somthing that will give a little better milieage an i can turn it up an have some fun . I dont need anything crazy . Thanks very much for your time
slickricks7.3 is offline
post #2 of 27 (permalink) Old 04-29-2009, 11:22 PM
Official TDG Doctor
hccumminssmoke's Avatar
If you want something on the fly go with a Comp and Gauges or a Juice w/ Attitude...if you just want a programmer then DEFFINITLY go with a SMARTY!!! They are the ****!
Nate
hccumminssmoke is offline
post #3 of 27 (permalink) Old 04-29-2009, 11:48 PM Thread Starter
im thinking of putting gauges in no matter what . So with already having them what should i go with ? I heard good things about smartys
post #4 of 27 (permalink) Old 04-29-2009, 11:52 PM
Official TDG Doctor
How much power do you want? and do you wanna change it on the fly?
Nate
post #5 of 27 (permalink) Old 04-30-2009, 12:12 AM Thread Starter
i just want to maybe up the milieage alittle bit an some more power but nothing crazy . I dont really care if its switch on the fly. were would you recomend getting a smatys from ?
post #6 of 27 (permalink) Old 04-30-2009, 12:20 AM
If you don't have gauges yet go with a edge juice with attitude and it will save you money. it's adj on the fly and you have 4 gauges you can watch at a time, but also set alarms for low fuel pressure, high speed, egt etc. I really like mine. Or if you have gauges go with the comp. You will be bored with the smart real quick
01quadcab is offline
post #7 of 27 (permalink) Old 04-30-2009, 12:56 AM
cowboytw13's Avatar
Regardless of which you put on, you will need to upgrade the lift pump, and probably the clutch as well.
cowboytw13 is offline
post #8 of 27 (permalink) Old 04-30-2009, 01:04 AM
Official TDG Doctor
Bob Wagner @ www.smartypower.com or DTR has them...where are you located...
I dont like the Juice gauges NEAR as much as Machanical ones...and you wont get bored w/ the Smarty that quick...its a fun little tuner...
Nate
post #9 of 27 (permalink) Old 04-30-2009, 01:30 AM
Cummings24v's Avatar
juice w/attitude best bang for the buck!!!
99 2500, NV4500
4" to 5" pipe, custom made
Edge Comp
BHAF
Raptor 150
EGT, Fuel, Turbo, Oil pressure gauges
285x75x16 Destination MT's
2 stroke oil diet
Cummings24v is offline
post #10 of 27 (permalink) Old 04-30-2009, 02:47 PM
mpg
I got an extra 2 mpg when I added an Edge/juice and then two more with
a four inch exhaust. now at 22mpg if I keep speed down.
2002 Dodge 2500 SB club-cab 6-speed Edge fass 4'exhaust two-stroke 2”level kit posi rear end
road runner is offline
New Cummins Owner fjo 6.7L Cummins (2007.5-2011) 3 01-15-2009 01:29 AM
New Cummins Owner BlackBetty 5.9L Cummins (2003-2007.5) 5 04-07-2008 09:47 PM
New Cummins Owner 95psdF250 5.9L Cummins (Pre 1994) 11 12-15-2007 05:20 AM
New Cummins owner dieselteel 5.9L Cummins (2003-2007.5) 4 11-25-2007 02:09 AM
Maybe a new Cummins owner jdecker88 5.9L Cummins (1998.5-2002) 6 10-13-2007 12:07 PM
