Power steering pump/Vaccum pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tbroadus_41, this thread has received 2 replies and been viewed 1346 times.
post #1 of 3 (permalink) Old 04-30-2009, 01:59 AM Thread Starter
tbroadus_41's Avatar
So the seal between the two has been leaking for some time now on my truck, i've been going to fix it but you know how working outside in winter is. Point being, today i drove my truck thirty miles give or take and then shut it off and went into the store. came back out fired it up and pulled up to the highway to turn out when i noticed an unusual sound. It kinda sounds like the vac pump but at the same time it sounds like an engine noise. When I pulled over to check it out it sounded like it was coming from above the two pumps but with the motor running it was hard to tell, and when you drive off it goes away maybe being the engine gets louder or it just happens at ilde? Have any of you had or heard of somehting like this before?
tbroadus_41 is offline
post #2 of 3 (permalink) Old 04-30-2009, 02:20 AM
Try resealing the vacuum pump. Its a really common problem and not that hard to fix. Get the kit from Fixinrams.com Works like a charm. Or maybe give them a call and see what they say.
post #3 of 3 (permalink) Old 04-30-2009, 02:43 AM Thread Starter
What exactly do you have to do to get to it? Do you go in from the top or the bottom?
Power steering pump? Foxx 1994-2003 7.3L Power Stroke 3 12-06-2007 11:38 PM
power steering pump tbroadus_41 5.9L Cummins (1998.5-2002) 15 11-14-2007 01:34 PM
power steering pump nomad Duramax 2001-2004 (LB7) 1 04-06-2007 04:10 PM
power steering pump BigWhiteSicksO General Ford Truck and Excursion 4 03-29-2007 09:02 PM
Power Steering Pump sstockton 1994-2003 7.3L Power Stroke 1 12-14-2006 06:41 PM
